myles
Autonomy Expert
- Jan 24, 2021
- 291
Hey Guys,
Thanks for reading first of all! :D
You can see my setup here:
and here:
I am definitely going to make ALOT more videos to help those that are in need of a modern actual off grid living approach, i would not go back, its too much fun, which is why I am here! :D
OK I need some help here, I really want to be off grid fully, but having a hard time justifying not bringing in a natural gas line and need some clarity in my thoughts from the community. Currently we a are fully off grid but we have propane for the boiler.
Firstly location: Close to winnipeg, manitoba to help with calculations.
Secondly, the Goal: Stay off grid without Gas line for my boiler.
Current configuration: 10.7KW (plans to add another 5k this summer) solar bifacial, Sol-Ark 15K, 1120AH lifepo4 48v, IBC Modulating Condensing boiler 14-115k, IBC indirect hot water tank, 50Gal Elec hot water tank, senville mini splits (4 heads total) for A/C in summer.
Current heat loads (INCLUDES DHW).
Our house is 2500 sq ft slab on grade modern build lots of south glass exposure, heavily insulated 9.25" walls from greenstone building products, 3" under slab insulation and around perimeter plus frost protect, R30 spray insulation to flat ceiling (1:12 pitch), its been -30*C outside with the sun shining its 80*F inside, we use the blinds to moderate the day temps, this is not a big deal. I keep the floor heat at 76*F and the house is very comfortable.
House real world performance statistics: 0.6-0.7 air changes per hour building envelope, currently I am using 660,000 BTU/ day to keep the slab at said 76*F with a *2F. Since its a condensing boiler your goal is to run that thing as cold as possible for efficiency. The boiler chugs along at 14-25K btu almost constantly to maintain the desired temp in the house (including keeping my attached garage at 58*F constant (sub note, the garage floor heat only cycles maybe once every two weeks to keep this temp being attached to the house with the same building methods very efficient!)).
So if we do the math I need 27,500 btu/hour to supply all the heat to the house, and the DHW. Currently I am getting about one full DHW tank per day from the electric (see videos on how this is done), so thats a free 4500 or so btu, which then the propane boiler will not have to feed the indirect tank for.
please enligthen me as to the best way to get these extra btus, mainly for at night!
Option 1: I have room on the solark to Add more solar, and an air source heat pump to heat the floor to 80*F which will then drop to about 76*F by the morning (best guess, doing a test tonight shutting off the floor heat to check how much drop I get). (https://www.arcticheatpumps.com/buy-cold-climate-heat-pump/heat-pumps-evi-low-temp.html)
Option 2: Adding hideous solar collectors to heat the floor, I have 20 acres of property space is not an issue, but I really dislike the look of these
Option 3: Leave it as is and bring in a natural gas line cutting my cost of propane by 75%. Yes natural gas would cost 25% of propane, BUT there is a 18K bill to bring in the line.
Let the conversation flow :D
