cs1234
Solar Wizard
- May 9, 2022
- 2,305
To install my Hoymiles microinverters, all I need is a fused AC Disconnect switch and a line-side tap connection to the meter panel. It's like a 1-hour job for an electrician that coordinates the shutdown with the utility. Once the switch is installed, I would just need to connect the output of my microinverter sub-panel (AC combiner) to the switch. Done!
Solar panels, a bucket of rocks, plug-n-play microinverters, a combiner panel, and a switch? It can't get much easier than that, honestly!
Disclaimer: I'm not an electrician, and I would hire a master electrician into my business as legally required to do electrical parts of the work that require it, as well as advise me, because I'm not an electrician, etc..
That being said, am I missing the part in the above quote where the Hoymiles available at an affordable cost would be zero export so you don't have to get a grid connect agreement?
And wouldn't you have to pull a permit in many jurisdictions to do that easy one hours worth of work anyway? I'm not as familiar with the electricians side of things as I want to be, but from my reading of various laws (in Texas) anything involving a new circuit or installation of a subpanel requires a permit and possibly an inspection?
