All,
@Craig has a thread going about his search for an SSR replacement for the relays.
https://diysolarforum.com/threads/ssr-testing.5347/
As part of that thread I proposed magnetic latching relays. These relays are usually controlled one of two ways:
1) Reversible coil: Positive pulse turns on, negative pulse turns off.
2) Dual coil: Pulse on one coil turns on Pulse on other coil turns off. (These seem to be a bit less common)
The key is that the coil is only pulsed. It does not stay on. This means you would have extremely low energy to power the relay (Like an SSR) and still have the extremely low voltage/power drop across the contacts of a relay.
Ideally, the Chargery would have a relay board that provides the pulse for driving a latching relay. However, something like this could be done using a positive-negative pulse magnetic latching relay with auxiliary contacts:
NOTES:
Theory of Operation:
- Relay 1 coil voltage should be 12V to match the Chargery signal
- Relay 2 coil voltage should match the system voltage.
- The Weidmuller 1127150000 called out is a Din-Rail Mount SSR I have used in the past. Almost any small SSR with a 12Volt coil should work.
Turn On sequence
At this point relay 2 is on but not drawing any current on the coil. Relay 1 is on but only drawing about 20mA.
- The circuit as shown is the starting point with everything off.
Note that in this state, both sides of relay 2 coil are hooked to the positive, so nothing will happen.- The Chargery energizes the signal, causing relay 1 to turn on, connecting pin 1 of the coil of relay 2 to negative.
- Since pin 2 of the coil of Relay 2 is already connected to positive, the coil is energized in a 'positive' direction, energizing the load and flipping the auxiliary contact to B(negative).
- When the auxiliary contact on relay 2 flipped to negative, both sides of the coil of relay 2 is connected to negative and the coil is de-energized. However, since relay 2 is a bi-stable relay, it does not change state.
Turn off sequence
Note, the opposing diodes (D1 & D2) across the coil of relay 2 are there to drain the voltage spike that will occur when the coil is de-energized. (You could probably do this with a single zenor diode). This is important for protecting the output of relay 1.
- The initial condition is that relay 1 is on and the bi-stable relay is on but the coil is not energized because both sides of the relay 2 coil are connected to negative.
- The Chargery turns off the relay signal so relay 1 switches state, connecting pin 1 of the coil of relay 2 to positive.
- Relay two now has an 'Negative' energized coil with Positive on Pin 1 and Negative on Pin 2. This causes the relay to de-energize the load and flipping the auxiliary contact to “A” (Positive).
- Both sides of the relay 2 coil are now connected to Positive so the coil is de-energized but since it is a bi-stable relay, it does not change state.
Here is an example of a magnetic latching relay with auxiliary contacts.
https://www.alibaba.com/product-detail/magnetic-latching-type-dc-contactor_1500742311.html
Note: There is a similar design using a second SSR that does not require the auxiliary contact on the latching relay. (It is documented in Craig's Thread).
Warning: I am no longer pursuing using relays or SSRs so I have never built this. (I do not have existence proof it works) If anyone decides to try it, let us all know how it turns out.
@ FILTER GUY
this should modulate a permanant signal into a 100ms reset pulse for set/reset of latching relay.
BTY, this infomation was provided by Astronom in a different discussion.
