There are two versions of the document. Originally it said this:
Like you said, that is just plain old
WRONG. I bought it because of these published specs.
Here are links to the web archive showing the original document:
I contacted them in February and said 120v isn't working and they said, no 120v wont work, it needs 2 legs of 120v and a neutral. I told them that isn't what the document says and then a day or two later they updated the document to this:
The really shady part is, if you look at the URL of the "new" documentation (which was updated sometime in early March 2024), it was updated in place. They tried to make it look like this is the document that has been up there the whole time:
2023/10/EG4-6000XP-Inverter-Spec-Sheet.pdf
So I feel like I had the rug pulled out from under me and I'm looking for ways around it. I might just be SOL, but still, it's not a great situation. Don't get me wrong, the inverter is absolutely awesome, and I love it, which is why I want to use it and not a chargeverter
It's just that this bad documentation of an important aspect has thrown me off a bit.
The original document is plain old WRONG. The new document, I would call it confusing or misleading at best, lol.
