They sell shorter versions of the same bus bar that are 600A, pretty sure they are at least that, but they don't say in an obvious place.I am not sure the eg4-ll rack bus bars can handle 600A either but the batteries in the rack can do it.
In any case 4/0 cables from the 'hub'/bus-bar would be necessary for 400A alone.
In my case I'd be connecting it to a sol-ark, which is ~275AMP max continuous. Not sure about load spikes and if I should still do the double 4/0 hook up with 600A of fusing (combined or before the 0/4, connected directly to bus bar). But that may be getting off topic. reading another thread now for that. ( https://diysolarforum.com/threads/system-layout-questions-sol-ark-15k-and-eg4-batteries.48156/ )They sell shorter versions of the same bus bar that are 600A, pretty sure they are at least that, but they don't say in an obvious place.
If you need 600A you should probably run 2x4/0 independently fused at 300A on each cable. Your cabling and bus must match your fuses/breakers/load.
Isn't there some rule about having to be 3ft apart or something?
Yeah its like that rule where couples had to have one foot on the floor when in bed with someone else in a movieCan't have them touching and making little baby batteries. You have to buy new ones, not make your own.
That's how I learned how to do it. Took many years to break that habit, stupid movies!Yeah its like that rule where couples had to have one foot on the floor when in bed with someone else in a movie
Wonder how long it will take gen z folks to figure the reference outThat's how I learned how to do it. Took many years to break that habit, stupid movies!
I forgot to show that there's a door on the right side of the electrical panel. Let me update the picturePut the inverter to the right of the main panel, one battery underneath and the other either under the main panel or on the right hand wall. Alternatively the batteries I presume can also go one behind the other.
NFPA 855 chapter 15.5 states Individual ESS units shall be separated from each other by a minimum of 3ft. unless smaller separations are documented to be adequate as approved by the AHJ. UL9540A would be required for the exception.Isn't there some rule about having to be 3ft apart or something in the UL requirements?
I see what you're questioning. I don't think it means only 20 KWH per inverter. Any single battery pack stack rack can only be 20 KWH.What exactly is an individual ESS unit according to the regulations. Are we just talking about batteries here or are we talking about these newer combined battery inverter units?
But isn't the definition of an ESS an inverter AND batteries?I see what you're questioning. I don't think it means only 20 KWH per inverter. Any single battery pack stack rack can only be 20 KWH.
15.2.1 requires UL9540 listing. UL9540 can be obtained for separate components, for example Pytes batteries listed with Sol-Ark.
Well that is the 6 million dollar question and when I started researching it this morning, I saw that it can also refer to all kinds of mechanical and other storage devices too, like hydro, compressed gas and fly wheels etc.But isn't the definition of an ESS an inverter AND batteries?
Thats hilarious ! I was always so amazed at your organizational neatness, refreshing to know your human !What I don't show in the videos and posts haha:
That's nuts. When i bought my solar panels from SanTan i shipped 2 whole pallets of panels from AZ to TX for around that same price. Crazy.$ 450. to ship from Signature Solar , Yikes !!
As far as aesthetics go I agree its a great look... I'm still waiting on my 3 Power Pro batteries to pass UL certification to connect them to my two Sol-Ark 15k's in parallel. My setup was inspired by your latest setup with the 18kpv. Once thing I did find out in ordering my setup.... the warranty will be voided on the Power Pro's if you connect them with any batteries that are not 280ah.... see image or page 10 of manual. So the orginal setup with rack of Ruixu batteries will void the warranty on the Power Pro's. Keep up the great work.I didn't realize it until last night, but I think this battery is pretty sweet. The look, form factor, busbar with quick connectors, communication ability, internal heaters, outdoor rated and the list goes on.
Now I want to dump my server rack batteries. Which one would you rather have. This setup:
Or four of these:
I just love the look. I love sci-fi movies and I want to make a system that looks really cool. I'm thinking four batteries and an 18K would do everything I need.
The communication set up was a bit difficult. I should probably make a setup video for beginners. I think anybody could figure it out though if they read the whole manual. I think there should be a tutorial on designating the master battery right after the communication protocol set up.
But besides that, this battery is pretty impressive. I'm going to be asking all of the other companies why they don't have this type of battery. Hopefully we can get some healthy competition into the market.
What do you guys think. Is there anything that you dislike about this battery that I'm missing? I really didn't think I was going to like it but seeing it in my shop in person, makes me want only these batteries now. I think I might move my server rack batteries into my garage today. I only have two power pro batteries but I could run everything I need with them. I'm almost at 5 megawatt hours with my 18K, so I really don't need to push tons of loads through it anymore. Making a beautiful system would be fun. I want to add LED lights behind it and make it pop
A follow-up. This thing is awful. the 4.5KVA unit ships with two L6-30S, and two L5-30S. We paid an electrician to wire it. He did not secure the ground from the panel and wired a short Y-GND on one of the L6-30P pigtails to the overhead distribution outlets. This short blew the power module as soon as it turned on. No, it did not trip the breaker, it blew the power module. The batteries are in a series parallel arrangement 60v x 2 = 120v pairs. Based on the label there appears to be a 40A DC fuse on the 120v.. There is a 30A breaker on the L6-30 plug. When it turned on it immediately blew the non-serviceable DC fuse inside the power module, and reported same on the front panel. A stunningly poor design for the power module. NOTE: this is an online UPS, runs off the batteries all the time.I have an EATON UPS here with pluggable battery modules:
3K model will set you back 5 grand. Figure $28K for 15KW. But a lot of that cost is the power/inverter units. There is no reason why you couldn't build a similar battery module that slides into a rack like this. Connectors are not that expensive, and the engineering does not have to be that precise. Plus these battery modules are not that heavy therefore fairly easy to install.
IMNSHO, Signature Solar and friends should really work in this direction. 100+ lb massive battery units is not the best long term solution. Multiple smaller units like this would be more easily transportable and recyclable.
