I am wondering if anyone has had experience with Amy replacing defective cells. I purchased 8 Grade A EVE 280Ah cells from Amy last year and assembled two 12 volt batteries that were used at a summer camp in an off-grid system. The batteries worked very well throughout the summer and all of the cells stayed well balanced. At the end of the summer, I noticed that one of the cells was refusing to be balanced. I tried balancing while charging and discharging with no effect. I disassembled the battery and connected the cells in parallel and top balanced them to 3.5 volts. I then disconnected the cells and monitored their voltages. The one problem cell voltage started dropping and has continued dropping while the other 3 cells have held steady.
I messaged Amy Nov 18th about the problem cell and she responded 3 days later asking for more information and pictures which I then provided. She then messaged me Dec 16th wanting a screenshot of the BMS (a JBD from Overkill). I responded with a detailed explanation of why I feel the problem is with the cell and not the BMS. I have not had any further responses from Amy. I have messaged her on a weekly basis but to no avail. I can see that she is reading my messages but is not responding.
There is no mention of product warranties on Amy's website that I can find, so I am wondering if I am out-of-luck as far as a replacement battery.
