Oldtimmer69
- Jun 20, 2020
- 254
My build thread.
EG4 6500EX 120/240 Setup, 48V 105kWh Battery & Overkill 100A BMS Install
EDITED: I've made this my build thread, so while there is an OP question below if you keep reading I'm slowly posting updates of my entire system. Mods please feel free to move if desired. System summary: (2) EG4 6500s for 120/240V config. (40) Hyundai 390W panels in 10s4p to stay under 500VDC...diysolarforum.com
Wher did you get those bus bars? And where are yoir 60amp breakers tied in from your inverters?I have 600A busbars. (8) DIY banks of 105kWh LiFePO4.
My offgrid panel is a QO 225A.
Square D - QO142L225PG 225-Amp 42-Space 42-Circuit Indoor Main Lug Plug-On Neutral Load Center with Ground Bar https://www.amazon.com/dp/B00CONGERO/ref=cm_sw_r_apanp_WI5ILZdazs9ky
My grid panel is a 200A QO.
2/0 is what the manual calls for from bus to inverters.Can i use 2/0 cable from the bus bars to the inverters, or 4/0?They'll all be 36" long. I'll run 4/0 from batteries to bus bars.
Where do you have the 60amp breakers that tie your inverters in?
over heating ad shuts of after 10 seconds
That one inverter from start up gave me the 02 fault.any loose connections? do you have a heat camera?
also how clean are the Anti-Dust filters at the top of the inverter? Mine got pretty dirty really fast after first installing them, probably because of all the dust created from the sheetrock, cement board etc. (looks like you used the same cement board as I did).
I know you havnt really been using them, but the Anti-Dust filter being dirty seems to be the most common cause of overheating.
Also, did you try it without PV? The fans on mine run the most when converting PV to charge the batteries. PV to AC less so, and Batteries to AC even less.
Im going to call as soon as they open tomorrow. I definitely hope we can fix through trouble shooting for sure. I was hoping to be back on my system by the weekend ? still hopeful ?. I appreciate you trying!Maybe a good idea to start communication with Signature Solar sooner rather than later. It seems like sometimes it takes a while for them to replace stuff if there truly is an issue. Also, they will probably give you some suggestions for troubleshooting or things they want you to test before they replace it (if it turns out to be defective).
I spoke with SS today.. Tried to re-flash the firmware but the inverter will not stay on long enough to make it happen.There are a few experienced 6500 users in this thread already that might have other ideas as well. I imagine they will give their input soon enough
Will the inverter run with solar or bypass? Sometimes that will allow you to change settings and do things even though it’s not technically on.I spoke with SS today.. Tried to re-flash the firmware but the inverter will not stay on long enough to make it happen.
Was ask to send a bunch of pictures and volt meter readings to show i had everything hooked up correctly. Haven't heard back from them so, i just waiting to send defective unit back. Looks like my system will not be up and running this weekend.
I haven't tried, but as soon as it comes on and runs the start up.. It goes red and F02 does a 10 sec count down and turns off. Just not enough time to update. Hopefully they'll send me one fast. I dont want to get jerked around to long paying a electric bill. 2 inverters are not enough to run my house..Will the inverter run with solar or bypass? Sometimes that will allow you to change settings and do things even though it’s not technically on.
Run what you can with 2. Try turning the inverter on with solar on it. I’m just curiousI haven't tried, but as soon as it comes on and runs the start up.. It goes red and F02 does a 10 sec count down and turns off. Just not enough time to update. Hopefully they'll send me one fast. I dont want to get jerked around to long paying a electric bill. 2 inverters are not enough to run my house..
It will stay on in bypass but it says connection fails after a few minutesRun what you can with 2. Try turning the inverter on with solar on it. I’m just curious
