I have 6 panels tested each panel 18.9 volts
at the inverter 26.6 with 289 watts right now with the full sun, I have no seenn it go higher than 340 watts it was 100 degrees max sunshine
2 set (3) in series then - parrel connected at 56.9 volts at the meter
MPP SOLAR 2400w Pure Sine Wave Power Inverter with 50A PWM Solar Charger DC 24V AC Output 110V 120V with 60A Utility Charger 50HZ or 60HZ
Thanks in advance
So why am I only getting 300 watts from 6 panels on a sunny day with no clouds - the sun is directly over the panels the pannels are mounted on the roof and 35% angle roughly
Jerry
RICH SOLAR 6 Pieces 100 Watt 12 Volt Polycrystalline Solar Panel Black Frame
24V HAWK
LiFePO4 - 170Ah - 4.3kWhMPP SOLAR 2400w Pure Sine Wave Power Inverter with 50A PWM Solar Charger DC 24V AC Output 110V 120V with 60A Utility Charger 50HZ or 60HZ
Thanks in advance
Jerry
