Well darn, thanks for replying.Unfortunately I can't recommend it because it died after 12 hours of use.
The downside is, this increases the overall length by 2 inches. I'll have two rows of 4 so that's another 8 inches per row. I think I have the space for that but I'll need New Horizons to do some measurements for me. It again makes me think about using 8 cells per fixture...
Cutting the 1x1 square tube with my 6" chop saw and a metal blade wasn't bad but the ends needed a lot of work to clean them up (with a dremel).
I also haven't yet figured out how I'll safely mount these in the RV ... I can't inhibit the movement. Maybe strapping them down lengthwise would work. I'm open to suggestions that doesn't increase the height.
Here's my next prototype. Square bar on both sides, 5/16" rod, and I moved the upper and lower sets closer to the center. I'm also using deconstructed CALB flexible bus bars (2 pieces for each series connection). The battery is at about 0% and I set all springs to 30mm and I'll observe changes along the way. I also measured the terminals between the bus bars so I can compare afterwards. Charging at 10 amps - so this will take ~28 hours.
Your battery cable to shunt is an example of what I think could apply torque to the nut and loosen it.
I suggest securing cable in some way. Shunt mounted to the assembly would be one.
If you used U-channel instead of square tube, or if you used a hole saw to countersink the spring assembly, you could get back a couple inches.
May need to do something to access stacked nuts if you use those like another member, but that isn't shown in this picture.
This was to be expected. Maybe the engineer thought you could get an extra 5 or so amps by taking down to 2 volts... We don't know what he was thinking but it would still be nice to know his reasoning. Anyway you did everything you were asked to do. Great updates from you. Thanks..4th test complete. Same as before - 269.
Mine says im on the newest firmware, with no updates available....it is a right bugger not being able to decrease this value down to 1V, which might prove reasonable for the flat curve of lifepo4
When you said yours got fixed, i take it you can lower that value now....what options do you get?
Hmmm, thats a significant percentage difference on that 4th spring. I suppose you will eventually glean more info on repeatability, but i'm certainly curious why that one was different!20% SoC and 3 springs have compressed 0.5mm and 1 by 0.8mm
No terminal movement.
Many thanks for those screenshots....so it looks like yours is different to mine, since my min default is 2v on a 24v system.
That looks very much like my compression fixture. I was top balancing all 8 cells together this weekend so I made it long enough for 8. My final system will compress four cells per stack (like yours) so I will end up with two compression fixtures.Here's my next prototype. Square bar on both sides, 5/16" rod, and I moved the upper and lower sets closer to the center. I'm also using deconstructed CALB flexible bus bars (2 pieces for each series connection). The battery is at about 0% and I set all springs to 30mm and I'll observe changes along the way. I also measured the terminals between the bus bars so I can compare afterwards. Charging at 10 amps - so this will take ~28 hours.
I plan on using bulkhead connectors mounted into the wooden end plates, then use braided straps to make the connection to the cells. That way pulling on the cable, doesn't pull on the cell.Your battery cable to shunt is an example of what I think could apply torque to the nut and loosen it.
I am mounting rubber isolators under the bottom bar. These isolators will thread into cleats secured to the floor of the van. You can see the rubber isolators in the first pic I posted two threads above this one.The downside is, this increases the overall length by 2 inches. I'll have two rows of 4 so that's another 8 inches per row. I think I have the space for that but I'll need New Horizons to do some measurements for me. It again makes me think about using 8 cells per fixture...
54% SoC. I now have 0.4, 0.5, 0.6, and 0.8mm of spring movement. No terminal movement.
When you say ‘no terminal movement’ does that mean the bottom is expanding by an average of 0.65mm but the top (where the terminals are) is not?70% SoC. 0.4, 0.7, 0.6, 0.9mm spring movement. No terminal movement.
