zanydroid
Solar Wizard
The extra overhead from double conversion for a PC is not going to be that bad, have you considered it? 0ms transfer and inverter always on without potential to be naughty in the eyes of POCO.
? ? Fixed that up.I can’t believe that we all overlooked the main feature of this inverter!!!!!
@timselectric doesn’t have to correct the name of it nonstop. Only when the @42OhmsPA of the world insult it by referring to it as an EX and not an XP
I have considered it. What's a little lost efficiency between friends, right?The extra overhead from double conversion for a PC is not going to be that bad, have you considered it? 0ms transfer and inverter always on without potential to be naughty in the eyes of POCO.
My UPS are Left over from before solar.Why are y’all using ups? Is this a grid tie thing or?
I just plug my electronics into a surge protector. Have had a couple unexpected outages over the years but my gaming pc never cares.
Grid-tie thing unfortunately. I'm not off-grid and don't have nearly enough solar/batteries to run all my computers off of 24/7.Why are y’all using ups? Is this a grid tie thing or?
Makes sense. I was assuming it had to do with the switch from grid to solar or back.Grid-tie thing unfortunately. I'm not off-grid and don't have nearly enough solar/batteries to run all my computers off of 24/7.
Usually the PC's don't care about a random shut down, until they do. If/when that ever happens to you, you will understand the desire for a UPS.
I just bought a new computer, yesterday.Usually the PC's don't care about a random shut down, until they do. If/when that ever happens to you, you will understand the desire for a UPUPS.
I mean that can happen too. AIOs despite their UPS mode aren't really engineered to be UPSes.Makes sense. I was ASSuming it had to do with the switch from grid to solar or back.
Just think of it as having the capacity to put more of the house on a UPS ?Guess I'll just need to get something like this 6000xp, a chargeverter and double conversion it. Something even smaller than the 6000xp would work nice though. A 3000xp with only 120vac.. especially if stackable.
That would be nifty. I could have my microwave and toaster on a double conversion UPS !Just think of it as having the capacity to put more of the house on a UPS ?
One issue with the oversized inverter is that they can come with a bigger minimum size battery requirement… see the thread from that forum member who decided to live dangerously with the XW’s minimum battery size.Guess I'll just need to get something like this 6000xp, a chargeverter and double conversion it. Something even smaller than the 6000xp would work nice though. A 3000xp with only 120vac.. especially if stackable.
That's probably only for prepackaged UPS's that include batteries I would imagine?Another thing about UPS listing is that there’s some building code updates in the works to clarify that UPSes are exempt from UL9540, and some of the proposals require the UPS to be listed as such
Not sure, I only read my first UL spec this week (9540), and I need a few weeks to recharge before reading the next.That's probably only for prepackaged UPS's that include batteries I would imagine?
Luck would have it, my cousin Eddie works for EG4. I just got off the phone with him. He works in the advanced research department of resourcing. He said their stickers work on almost any inverter or battery and no options are off the table. He said to not worry. You will have your cheap chinese AIO in one form or another. Power to the minions!Anyone have the inside scoop?
If I were double conversioning it using a chargeverter, that would be taking the place of some of it's battery.. when there's power of course. It would have 200ah of 48v battery for my first tests though.One issue with the oversized inverter is that they can come with a bigger minimum size battery requirement… see the thread from that forum member who decided to live dangerously with the XW’s minimum battery size.
48V also doesn’t help with keeping it smol
I didn’t look at the min battery spec of 6000XP but I’m sure that is plenty of battery.If I were double conversioning it using a chargeverter, that would be taking the place of some of it's battery.. when there's power of course. It would have 200ah of 48v battery for my first tests though.
That's the bare minimum they recommend in their spec.I didn’t look at the min battery spec of 6000XP but I’m sure that is plenty of battery.
Bet tomorrow Eddie will be called into a different EG4 department.Luck would have it, my cousin Eddie works for EG4. I just got off the phone with him. He works in the advanced research department of resourcing. He said their stickers work on almost any inverter or battery and no options are off the table. He said to not worry. You will have your cheap chinese AIO in one form or another. Power to the minions!
