Zapper77
Renaissance Man
- Jul 23, 2022
- 2,326
A. Correct (I only had one night, 3 days ago when low SOC hit the "grid cutoff" threshold) so haven't been able to completely test it...I've done simulations and it worked.A. Wow now i feel dumb! LoL ? makes total sense that was a dumb question. Thanks for your patience, maybe at least it’ll help someone else when they read your explanation.
So just so i can understand, the reason we are doing this is because that way the inverter side will remain active thus as soon as the sun can start charging it’ll do so without hesitation nor needing my invervention. Clever
B. Got it now. I’m clear now. Thanks again.
C. Regarding the bug, thats all they told me, no further explanation, they remotely reinstalled firmware and maybe did some other stuff. But im back to feeding the load and not on EPS mode anymore. The grid helped the inverter to charge my car at 11,000w plus 3,000w of the rest of the house, it couldnt do that on EPS mode. It was either the batteries/solar OR the grid, its not able to assist with loads. This is much better i think.
Lets see if i dont get the export problem again. I see it showing it “exported” 0.4kW today.
C. Well this will be interesting...I assumed you were still on the EPS only mode firmware.
Are you doing upstream grid assist or just a critical load panel?
