12VoltInstalls
life passes by too quickly to not live in freedom
•Unit is to number what grammars are to word.
For anyone with an iPhone or iPad, hold down the zero key to get the option to enter the degree symbol. Super easy.Although my iPhone is alt sensitive I hear, unless I remember ascii- 32*F is comprehensive enough isn’t it?
Strange. I’ve never seen that happen.And sometimes KWh -like right there!!! - spell checks (typed kWh) and I give up
Please see post #1. That should be Ah. The use of / means "per" (divided by). It's not amps per hour, it's amp hours which is really short for amps times hours.100 a/h battery
Sorry to be pedantic but given this is a thread about correct use of terminology...Watts are a measure of work performed by the current.
AlsoThe following are common units and their abbreviations. Note that unit abbreviations are case-sensitive. While some units can be understood when written incorrectly, some have a completely different meaning if the wrong case is used. Avoid any possible confusion or ambiguity and use the correct case.
A - amps. Named after André-Marie Ampère.
V - volts. Named after Alessandro Volta.
W - watts. Named after James Watt.
Ω - ohms. Named after Georg Ohm.
h - hours
k - kilo (SI prefix for 1000)
K - Kelvin, a unit of temperature named after William Thomson, 1st Baron Kelvin. Not really relevant in solar discussions.
m - milli (SI prefix for 1/1000)
M - mega (SI prefix for 1000000)
Current is measured in amps - A
A battery's current capacity is measured amp hours - Ah
A battery's energy capacity is measured in watt hours - Wh. Many times it is shortened to kilowatt hours - kWh. Example: 5120Wh or 5.1kWh.
An inverter is measured in watts - W. Many times a value is shortened. 4000W can be written as 4kW. Really large systems could be in megawatts (MW) or even gigawatts (GW).
A battery's voltage is measured in volts - V.
A wire's resistance is measured in ohms - Ω. Many times the resistance is very small such as 0.002Ω commonly written as 2mΩ.
AC vs A/C - AC is alternating current. A/C is air conditioning
While not a unit, one common abbreviation that should be written correctly is for Lithium Iron Phosphate batteries. The correct written form is LiFePO₄ though most people find LiFePO4 is much simpler to type. LFP is a shorthand abbreviation understood in the context of this forum when discussing batteries. Incorrect abbreviations would include LiFePO (lithium iron phosphorus oxide), LiFePo (lithium iron polonium), LiFe (lithium iron). Note that there is a lithium polymer battery typically written as LiPo. That is not at all the same as LiFePO₄. You do not want to confuse the two types. Though both of those types are specific examples of the more general lithium-ion (Li-ion) batteries.
I believe the speed of light is c (lowercase).So what is C ?
Capacitance or the speed of light ?
While I don't personally like a space between a value and its abbreviated units for aesthetic reasons, the use of a non-break space eliminates the issue you mention. When typing a document in a word processor you should be able to enter a non-break space. On a Mac this can be done with option-space. Not sure about Windows, maybe Alt-space. In a web document you can use . A non-break space prevents the text on either side from being separated across lines.I agree with one of the reply of another user, that there should be a space between the value and its unit, such as using 25 ºC and not 25ºC, but I like how the lack of a space holds information together on one line if it would otherwise be split up by a carriage break, so I tend to let that one slide.
Thanks for the reply, as I didn't know that was an option. I looked it up, and for MS-Word it is Ctrl-Shift-Space.While I don't personally like a space between a value and its abbreviated units for aesthetic reasons, the use of a non-break space eliminates the issue you mention. When typing a document in a word processor you should be able to enter a non-break space. On a Mac this can be done with option-space. Not sure about Windows, maybe Alt-space. In a web document you can use . A non-break space prevents the text on either side from being separated across lines.
Because not all batteries operate/supply the same voltage.Please explain why watt hours is a better measure of amperes that can be pulled from a storage battery.
My thinking is 1000W is 71 amperes at 14 volts and higher amperes as the battery voltage drops closer to 12 volts. Storage batteries store and accept amperes. The storage capacity of a storage battery is amp hours. Watt hours vary with battery voltage. Amperes in or out don't.
Yup. Watt hours are useful and necessary but there’s not a static baseline convention for that. Though from what I gather lithium is a linear output, lead is not.AH changes according to the discharge rate
Easy...Please explain why watt hours is a better measure of amperes that can be pulled from a storage battery.
And yes. watts are power used by the device, doing Work. to quote wiki "one watt is the rate at which electrical work is performed when a current of one ampere (A) flows across an electrical potential difference of one volt (V)," 745.7 watts is one horsepower. Again work.
Often spell check on this and other forums will not recognize some "whole" words and ask for a hyphen. I think as humans we can recognize a hyphenated word with no confusion.
The amp hour number rating posted on a battery is determined how?
a? A? eh? On an electrical forum is the capitalization of this all that important? I do appreciate the problem with alternating current and air condition.
Na. We be too pedantic, yes? correct use?
Wait wait don't ban me again. I promise to endeavor to use the correct initialism, acronym, punctuation, and capitulation.
for a while anyway..
And I will not ask anymore questions.
Just to be mean, I will post the entire long link from Amazon from time to time.
