Hedges
I See Electromagnetic Fields!
- Mar 28, 2020
- 21,553
Yeah, its copper. I know this picture makes it look like aluminum, but it's not. I have all 3 of their cable sets and I just checked them now at the crimps, and they are copper. I highly doubt anyone would make an aluminum wire with this type of insulation. The 200C insulation is the good stuff. And I also just verified with my cable sets that they are all using 200C rated insulation as I remember.Maybe the strands are so thin that I can't tell, but I don't see any copper. Even if they were copper, wouldn't 175 amps over 12 feet of 6awg wire be pushing the limits, and potentially unsafe? Or is it the 200C rating that makes it okay?View attachment 26969
@Will Prowse Thank you for the information. I'm still glad I made my own thicker wire connections, but I feel bad for calling out BigBattery like I did.
Vdrop = 175A x (0.0004 x 12ft)
= 0.84V Voltage Drop
Ploss = 175A² x (0.0004 x 12ft)
= 147W Power Loss
At Mid SOC (13.2V) that is:
Voltage Drop = 6.4%
Power Loss = 6.4%
I see they are now 50 years old, which would mean when I first used them they were 10 years old. We used the Tenney Jr in a computer manufacturing and test lab, and much bigger custom chambers for manufacturing burn in testing.I just need to buy a freezer and cycle them a few times. Then we will know.
My understanding is that lithium plating would show up in a capacity test result after a single cycle.
I will buy the coldest freezer I can find.
Do you automate test equipment operation? (Labview, VEE, Python, Matlab, Basic, whatever)
Hello @ghostwriter66,I honest to God hate it when companies like BigBattery try to throw something out there that on the surface is technically correct BUT the way they are doing it is BULLSHIT. SOOOOO now we are going to have this damn conversation - again - for the second year running - about charging while below freezing ... YES you can do it - YES you can EASILY ruin your battery if you do it wrong -- YES you are charging at a barely minimal rate and NO these batteries will NOT recharge 100 or 50 or 20 or even 10% the next day ... SOOOO what pisses me off is that good people - these guys that live in the cold - in RV's and Tiny homes are going to run out and buy these batteries because BigBattery marketing department tried to get "cretive" in their advertising and the consumer now erroneously thinks that they can fully recharge their batteries below freezing to make it through the night and BB knowing that 99.99% of the ppl out there do not understand the difference between 2C and 0.1Ca ....
@fat_old_sun,Not defending Big Battery, but they are *not* a R&D house. They're in the business of inventory turnover. However, if they prepared the datasheets without verifying the specs, it would be irresponsible (& may even be criminal). They're very likely repeating what their unscrupulous suppliers have told them. VW, Theranos and so many others have done it. It's ultimately the consumers responsibility to vet these claims - not an easy task.
@Will Prowse ,I am going to freeze those cells to -20C, and charge at max rate. Repeat. Then capacity test, or test internal resistance with my cell monitor.
And I do not trust any company or distributor. @fat_old_sun is correct, and the only way to find out is to test it ourselves. Bigbattery has a qualified EE as head designer, and he knows his stuff. I am not sure where they found him, but he seems to know everything. I have thrown a lot of questions at him, and he always knows his stuff.
But yeah, lets test it!
@DKyleM18,@Will Prowse Thank you for the information. I'm still glad I made my own thicker wire connections, but I feel bad for calling out BigBattery like I did.
Will Prowse released a video over the weekend showing that the battery in fact charged/discharged @ as low as (-30C) (However we do not recommend this.)
@fat_old_sun,
Our data sheets are accurate, it was a mistake by our marketing dept. which was swiftly corrected. On (67) Units - our BMS was set to cut-off at (-5C), these batteries were taken back and recalibrated to low-temp cutoff at (-0C).
Although not advised, I believe Will Prowse brought our battery down to (-30C) and it still functioned - Although we do not recommend taking it down past (-0C) and our BMS will cut-off on all mass-produced packs at (-0C).
Hang in there @MrGreen ... it will get better .... I know its an old joke to most but for a 23 yr old girl from LAX it was new to me and i laughed so hard when I heard it from one of the old wellhands the other day ... but it sort of fits what your going thru ... let see if I can remember it correctly ...
So a man walks into a bar, and sits down. He starts a conversation with an old guy next to him. The old guy has obviously had a few. He says to the man:
"You see that oil rig out there? Built it myself, hand crafted each piece, and it's the best oil rig in town! But do they call me "McGregor the oil rig builder"? No! And you see that bridge over there? I built that, took me two months, through rain, sleet and scorching weather, but do they call me "McGregor the bridge builder"? No! And you see that tower over there, I built that, best tower in the county! But do they call me "McGregor the tower builder"? No!"
The old guy looks around, and makes sure that nobody is listening, and leans to the man, and he says:
"but you fu#k one sheep..."
Hello @upnorthandpersonal ,Well, not really. The video showed that the battery could be put in a freezer, taken out in the nice Las Vegas weather, and then charged. This is of course completely different from using said battery in a constant -30C environment. In addition, low temp cut-off did not trigger which means that either a) the sensor failed or b) the battery wasn't at a low temperature at all.
I think you meant don'tAs per the (-30C), you are 100% Correct - We don't want anyone using our batteries in these environments as they are out of our parameters.
Can I have a clarification? Does this mean it cuts off charging at 0C or it cuts off operating at 0C?Our mass-produced run will cut-off at (-0C) now
Thank you.Hang in there @MrGreen ... it will get better .... I know its an old joke to most but for a 23 yr old girl from LAX it was new to me and i laughed so hard when I heard it from one of the old wellhands the other day ... but it sort of fits what your going thru ... let see if I can remember it correctly ...
Wait, you are paying for shipping BOTH ways?Hello @upnorthandpersonal ,
The low-temp cut-off does in fact work. Please have anyone test that has received our mass-production. We have sent many video's of this and happy to post them on our YouTube channel as well. As per the (-30C), you are 100% Correct - We do want anyone using our batteries in these environments as they are out of our parameters. Our mass-produced run will cut-off at (-0C) now and the (67) packs that cut-off at (-5C) have been recalled and recalibrated for free while providing those customers with credits for the inconvenience and covering all shipping/labor. We are doing the best we can and hope that no one uses our batteries other than intended.
Thank you for your input. Have a great day! : )
Sincerely,
Eric Lundgren : CEO
Eric@BigBattery.com
Great. If You run into a problem getting the temperature low enough, some dry ice would probably do the trick.Those have got to be crazy expensive-20C will do haha
edit: just ordered Midea, which hits -28C. So we can easily trigger the charging protection sensor on the -20C packs.
That should be interestingI am going to freeze those cells to -20C, and charge at max rate. Repeat. Then capacity test, or test internal resistance with my cell monitor.
Some Solar Controllers have a temperature sensor to regulate the amount of charge to the battery, but I believe this is only used on flooded and perhaps AGM batteries.One thing the above trend makes me think about is how useful it might be to have a charger (or maybe BMS) that 'throttled' current based on temperature as opposed to a simple 'on/off.' Victron controllers have low temp protection (with an addon) and are temperature aware, they also have the ability to manually limit current. It seems like this is all the building blocks for what I'm envisioning, the software would just need to be designed for this.
