Yes
Disconnect everything and put it in a grounded metal box.
Grounding is not necessary.
Yes
If the crap hits the fan with nukes, there is a big ass target on my area anyway, so I will probably not feel a thing.
We can only prepare for what we have the ability to. Some metal screening(faraday cage), ferrites, surge suppression and lightning arrestors are all I can do, but its at least something.
If that unistrut is a battery rack, its pretty cool looking. Is it 12 or 14 gauge?When I built the wall, I included a thin metal layer on the outside, and put up metal screen mesh behind all the equipment. The batteries will be in the metal rack, and enclosed with screen wire mesh around that also.
Would you have a link to those please? I am interested in them alsoAgree about the saturation issue. I am using the higher priced Fair-rite cores that are tested for high saturation. The ferrites from China are mostly crap.
If the big blast happens , just go outside and breath deep for a bit… you will have no worry’s soon… it will all be peacefull thereafter..Do solar panels survive? Charge controller? Batteries? Inverter?
We are probably doomed by fallout from exploded nuclear power plants anyway in the case of emp, but do we have any EMP experts in the house?
I Purchased mine at a garage sale from a Ham operator, but digikey carries most of the fair-rite products.If the big blast happens , just go outside and breath deep for a bit… you will have no worry’s soon… it will all be peacefull thereafter..
If you want inexpensive optics, look at fs.com. They are the go-to 3rd party optic supplier in my client base. They also sell low cost switches (though don't know of any enterprises using them). I expect they'd be fine for home use.I just saw I can get 4 x 1Gb SFP's for $64 on Amazon. Wow, prices have come down a bit on optical!
My business was Storage Area Networking and Fibre Channel, so I do have experience in that area, but in the Enterprise class gear. Any thoughts on a good 4 port residential optical ethernet switch that doesnt break the bank?
fully, use the both proffesionally as private..If you want inexpensive optics, look at fs.com. They are the go-to 3rd party optic supplier in my client base. They also sell low cost switches (though don't know of any enterprises using them). I expect they'd be fine for home use.
55mm is 2.16 inchesMake sure the inside diameter is large enough for your cables, like 55mm or (.72) for larger battery cables.
Thanks. Gotta stop smoking crack in the mornings... ?55mm is 2.16 inches
.72 inches is 18mm
{were pretty much all bilingual around here}
Two is one and one is none. I like three or more of everything lol; solar or other parts, bits, and bobs. I am going to implement a bar code system at some point for inventory control. Use one, order one. Was working on bolt bins before I went back overseas.Forget about protecting the equipment. Have a spare system in a tight fitting metal box for when the the dust has settled, hopefully not hot. It’ll be cheaper in the long run than trying to harden.On the upside, you got spares.
I have to admit, @12VoltInstalls ultimately convinced me to build (in addition to my main 48 volt system) a 12 volt and a 24 volt system.., I even went so far as to make them 4S 8S and 16S with the same cells for redundancy/interchangeability/ability to series connect the smaller batteries to provide an option for the next voltage up in an emergency.Two is one and one is none. I like three or more of everything lol;
Interesting. Does this apply to electronics that have never been powered up? Or even more?Should you plan on keeping spare inverters,(or any electronics) plan on at least every few years to pull it out, precharge and run it through its paces for a day. Perhaps rotate inventory. Capacitors don’t like to sit for a long time and those things are full of them.
We had some spare DC motor drives and the matching power supplies (think big industrial).Interesting. Does this apply to electronics that have never been powered up? Or even more?
