S Davis
- Sep 25, 2021
- 1,050
Ever see that stuff burn? I have. Its not good.x2 being a good idea
I want to prevent shorts. If it is burning, I have bigger problems by then.Ever see that stuff burn? I have. Its not good.
Fair point!If it is burning, I have bigger problems by then.
Same here. In this case with my portable build. The Multiplus handles neutral to ground bonding internally based on whether it is connected to grid or stand alone.I have been pondering this very issue for a while
Thanks for the thorough reply Steve.Well, 3 options, depending on how OCD you wanna be.
1) Make conductive connected for the case components so they are all physically bonded, then use a Self Tapping screw with serrated washer for the ground screw and run a ground lead from that to a proper "earth ground".
2) Just use a larger screw to clean the threads out with a lock/serrated washer and wire the ground, the case is likely already bonded (somewhat) because they are metal & screwed together.
3) Ignore it and continue onwards.
I have been pondering this very issue for a while. All my previous packs have never been grounded as such, given that the cases were made out of 3/4" Furniture Grade plywood. My update setup uses a Metal Shelf with composite shelves, it's completely isolated as the floor of the Powerhouse is covered with 3/4" thick rubber Horse Stall Matt... (Seemed a sensible notion due to all the power in there & the possibility of wet exists.) OKAY call it cheap insurance.
I am not going to worry about it, but I will ground the two metal racks they are going in.Guys, I talked about the ground for the battery cases. Each battery case has a screw hole for a ground on the removable face plate.
But I see a problem because the screw holes are painted. And the whole face plate is painted so the face place most likely doesn't make a good connection with the rest of the case.
My batteries never had a ground when I had them set up without the case so I am not supper worried about this but if I am going to set up a ground for each battery, I want to do it right.
Are you guys doing anything about these issues I mentioned about the ground screw hole being painted and the fact that the faceplate with the ground hole is painted and doesn't make a connection with the rest of the case?
Don't use the Internet to figure out your odds. I'm a firm believer in the mind being just as important as the body in the fight.Thanks for the thorough reply Steve.
I found a 4mm tap and ran it through the ground holes. It cleaned the paint out of the threads.
I will go to ACE hardware and see if I can find 4 mm screws with a flat head and I will get some serrated washers.
I will also try to make sure the face plate is making a connection to the main case.
The ground wire is going to be kind of ugly running across the front face of all of the batteries. I could make the ground work on the back of batteries.
I want my system to be safe and easy to understand for my wife and anyone else who needs to work on it when I'm not around.
I too have cancer and I am not expected to live much longer. My doctor says I could live a few more years. But when I look up my cancer on the internet it says my chances of living 5 years are almost non existent. My wife has been very good for me and I don't like leaving her alone.
My cancer treatment makes me sleep a lot and I often have trouble getting motivated to do anything. You are an inspiration because you always stay busy and you seem very motivated.
It absolutely is.Don't use the Internet to figure out your odds. I'm a firm believer in the mind being just as important as the body in the fight.
Did you get one or two? If shipping via pallet may not be much more for a second one added onAnd order/payment completed, now the wait. Thinking should be here by the 7/4 or at least mid July.
I would have thought shipping would eat up savings on a single battery, but your price is still $250 less than the 230Aah that LiTime is selling. Good to know!Just one case (single stud) and 8 280kv3 cells, jk 200a non inverter BMS.
$1130 delivered to my door (260$ for shipping). I don’t have a means to handle a pallet.
This will bring me up to 11kwhr for storage (8s230ah and now this 8s280ah) at the camp where biggest load will be a hair drier and coffee pot at the same time.
This second battery will be complete overkill. Right now I only have 340w of solar that will trickle charge when we’re not there.
Thanks for the positive thoughts guys. My current doctor is very positive and he says the new odds are much better than what the internet says. I am pretty good at keeping a positive attitude but I have to prepare for all possibilities. I am 66 years old and have lived a good life so it's all good.Don't use the Internet to figure out your odds. I'm a firm believer in the mind being just as important as the body in the fight.
Now that I got sucked into all this DIY power, I have about 5 years of projects planned. I'm kind of banking on the continued help and advice from the likes of you and @Steve_S. So the two of you have got to stick around!Thanks for the positive thoughts guys. My current doctor is very positive and he says the new odds are much better than what the internet says. I am pretty good at keeping a positive attitude but I have to prepare for all possibilities. I am 66 years old and have lived a good life so it's all good.
