Like so ?
Using 8 Cells of 280AH for 24V/280AH packs.
Bus Bars & BMS harness leads attached.
NOTE: I use a Chargery BMS System which is external to the box, hence the battery harness & temp leads attach outside on the front to the main BMS control module. There are double "pull strings" (orange with green tape over the knots) around each 4-cell bundle to help pull them out of the box if they need to be maintained.
