you may be the first test subject. I been watching to get reports and i havent seen any one post yet. But maybe some one will jump in. I hope will will review this BMSAnyone received this BMS yet or gotten it to work? I'm supposed to receive mine next week and wondering about the bluetooth connection. Thanks
Great !! i looking forward to the low temp cut off test.So i got my 200Ah 12 LTO daly smart BMS in mail yesterday. I downloaded the ap today and had issues registering. I messaged daly and they set an account up for me. (not sure why i need an account but that is for another discussion).
After I added my device it seems to report data well. It was pretty much within 1 or 2 mv of what my Chargery was reporting.
My cells are at 49 mv difference right now I will check in the morning to see if they change much. usually the Chargery keeps them under 20mv difference. I have both hooked up to same battery so I hope they do not fight each other. Currently I have no current running through the BMS. It is a common port which I do not like at all but I still wanted to give it a good chance.
here are some screen shots from the ap
Earlier in the thread it was posted no low temp cut off but this has a setting for it. I will try and test at some point.
View attachment 14528 View attachment 14526View attachment 14527
I paid on 5-19 and it was here on 5-30Craig, how many days did it take to ship?
I should've asked before...from China to U.S. in 11 days?I paid on 5-19 and it was here on 5-30
YesI should've asked before...from China to U.S. in 11 days?
I did had some starting issues today with the inverter...
(Together with the new BMS)
At powering up / turning on the inverter, the BMS seems to stop???
And go in to stop-start-stop-start loop.
I had similar problem I had to power cycle BMS to solveHmmmm....I wonder if that is some kind of surge popping the short circuit protect in the BMS. Is the inverter off? If not, it could explain the symptoms:
1) The BMS turns on
2) The capacitors start charging
3) The BMS thinks it is a short and turns off
4) The inverter is on so it drains what little is in the capacitors
5) The BMS trys to turn on again and restarts the loop.
I remember in one of Will's videos he did not pre-charge the inverter capacitors and the classic Daly BMS turned itself off when he tried to hook it up.
Setting up an inverter disconnect with a pre-charge position is probably a good idea.
BTW: I am still waiting on mine.
Very nice!Note: I just added a resource with the circuit I user for an inverter disconnect with pre-charge.
https://diysolarforum.com/resources/inverter-disconnect-with-precharge.60/
Thanks for this!!Note: I just added a resource with the circuit I use for an inverter disconnect with pre-charge.
It's already freezing at night where you live?I will tonight
no I will do thr iIce water trick.It's already freezing at night where you live??
