I'm not worried about the stuff in the basement (concrete block and metal cabinet). I just hope the installers did a good job on my roof!
right.... and theoretically, arc-faults are the cause of all roof-top fires. technically, arc-faults are the cause of all panel fires, as well.
soooo.... does that mean AFCI within the SCC is unable to effectively control panel-level arc-faults? and the correct answer is apparently... yes. in theory arc-fault is detected, SCC terminates panel load. it muse be the case that even in a no-load scenario, uncontrolled arcs are occurring.
yes, but the space shuttle wasnt designed by us hillbillies and rednecks... ?Hey hey hey…. your hittin close to home here… most hillbillies up here could give seminars on DIY stuff to most city folk…that’s all they have ever done.. damn clever people on many things…
we don’t know what happened with that boys gen set…. Many things including a gnawing possum could have been the cause….ya know the space shuttle exploded too…
Jim.
it would have never exploded if we built it. A rubber O -ring is what ya give yer girl when ya propose to her. ..not used on important rocket engines …yes, but the space shuttle wasnt designed by us hillbillies and rednecks... ?
I see your wind generator, but when you gonna show us your solar setup?it would have never exploded if we built it. A rubber O -ring is what ya give yer girl when ya propose to her. ..not used on important rocket engines …
.also after the first flight, it would have been turned into the worlds biggest Still ..
and producing even now.…
Damn……I’ve been found out…geeezzz..
I dove into that thread and when he mentioned Tesla modules and a default configuration I suspected the reason was overvolting the batteries. Tesla modules are a unique voltage that do not fit many default settings. The nominal voltage is 22.8 which is easily overvolted on any typical 24 volt default setting.
I also assume no BMS which if set properly could have stopped the disaster before the battery got hot.
I do not know for sure that is what happened but I have seen too many reports of Tesla modules being abused to not suspect that was the case.
I did not see any statements that concluded it was the MPP charge controller.
Yes, all could have been prevented with much better choices made by the person who installed the system.What a shame.
Well, everything that physically exists and is matter will transfer heat, so the usual most important factors are how quickly will something conduct heat through to the other side, and what is its auto ignition temperature, if combustible?On a related matter. I get that tile backer board is pretty fireproof but is it that much more fire proof than sheetrock? EG: Why do people put hardiboard on top of sheetrock? Belts and suspenders? Is sheetrock by itself not adequate?
I honestly have to give them some extra Credit for building the Kidney shaped swimming pool or Duck Pool.
Did you ever see the curves on Elle Mae Clampett..?…I honestly have to give them some extra Credit for building the Kidney shaped swimming pool or Duck Pool.
I thought Red necks detested anything that was not Square.
"This gravy train is a house of cards and that would be the straw that broke the camel's back. Please go away". When i cynically paraphrase him i actually almost believe it.“When you start mandating a fire sprinkler system, you are going to price a lot of people out of these new homes,” said Ned Munoz, vice president of regulatory affairs for the Texas Association of Home Builders, which lobbied heavily for anti-sprinkler legislation."
Wow.. defies physics ,but I feel it’s true as no one could make that up….. that just wasnt y’all’s day…I have done similar odd things as a kid… I really can’t explain how they happened.. but they did."This gravy train is a house of cards and that would be the straw that broke the camel's back. Please go away". When i cynically paraphrase him i actually almost believe it.
When i was a teenager me and some friends managed to catch a ceiling on fire by boiling some hot dog weiners until all the water was gone.. nothing on the stove actually caught fire but we managed to heat the ceiling enough to catch flame. I'm guessing the vent hood wasn't running or was on low but i can't remember. Anyway, i considered it sort of an impressive feat!
If you build it out of metal you can just start over after you clean up all the ashesI think I will build a solar shed after all....at least if that burns down it's a couple hundred in wood.
