Bud Martin
Solar Wizard
- Aug 27, 2020
- 4,844
I just received my REPT 280Ah grade B from 18650Batterystore today, 12-29-2022, these are Black Friday special for only $100 ea, + $65 shpd (4 cells) to N.Cali.
I test the Voltage on each cell, they are around 3.45V! it only took < 1hour to full charge each cell to 3.55V and <1A tail current, it means they are full charge when they shipped them.
The cells are well packed.
The welded studs are OK.
I did not want wait to put them in parallel and let them sit for hours before testing them.
I run the battery pack test with discharging current of around 40A, I had to stop at 11V before the Voltage goes down to 10V (2.5V/cell) because the inverter Low Voltage alarm was bugging me.
The test result is 286Ah, the Wh is 3600W but it is not accurate because there is no Volt sense on my tester to get accurate Wh reading, I'm sure I can get to 290A if I keep running it down to 2.5V/cell.
I'm happy with the result! especially at $100/cell is great price.
