At first I thought I didn't have any flicker issues. I had been testing and had the AC input turned off. Swapped 2 breakers around just to see if it would help on balance between the 2 inverters, my wife turned on the kitchen light and television in the kitchen and a very pronounced strobe effect started on the lights where the inverters are located. I swapped those 2 breakers back into the original position, the pronounced strobe did not reappear for those lights.
However, I do get the flicker on occasion, it is due to one inverter and the circuits powered by it. The swap of the 2 breakers confirms it is related to the one inverter. It is the slave inverter and not the master. I do not have any dimmers on my lights.
What have I observed? It is voltage fluctuation that causes it. I have it on a video, output voltage fluctuates between 112V to 126V on the slave inverter while the master is rock steady at 120V output. Of course, wattage on the slave output fluctuates due to the voltage fluctuation. Battery voltage is steady. The flicker will disappear as soon as the inverter output voltage stabilizes.
The problem is the inverter can not maintain line voltage, it's that simple. I doubt the firmware will help. I will check the firmware versions in both later today but as this was a pair, I'm fairly certain it will be the same version in both.
@SignatureSolarJames I will be in contact until the matter is resolved. I am quite certain the problem is voltage regulation.
