73powerstroke
I think that I made a mistake starting out with these 40 epever charged controllers.
I have 3 @$140 with 30days to return by the 20th. $550 for 120amps of cc at under 100v pv max array. Only 12/24v battery capability. Difficult to quickly read or track output.
They are rated 520w at 12v or 1040w at my current 24v system.
I have 240w 60 cell 2s3p on one controller for over paneling. 1440w ,About 15amps difference assuming 100% output. Helps with clouds.
The other has 2s2p. 960w so slightly under the 40amp cc ability. Probably 33amps max.
Then I have 2s2p 100w panels on another 40A CC. So about 13amps max.
So I cant possibly deliver more than 86 amps to my batteries at this setup. And to ad more panels requires more parallels. More current. I could certainly over panel the other group by adding 2s 240w panels.
So im thinking that I can return at least 2 of the epever 40amp tracer 4210an models and switch to something else that might handle all the 240w panels. Currently there's 10 but I can certainly at 2 more .
I think I might want to go to a 36 or 48v system later on. Santan solar has a lv2024 and I think a 3kw 48v one for $700 and $750 they also have a 60 and 80 epever that will support higher battery bank voltages.
I really dont think I have this the best way possible. I'm looking for ideas.
And the batteries I'm going to change later but I have 1 large deep cycle in series with 2p smaller deep cycle batteries. And the 3000w reliable 24v inverter. I'm running ac unit mostly, just during sun hours. I need to draw up a plan.
I'm basically playing around trying to learn what works best.
