timselectric
If I can do it, you can do it.
- Feb 5, 2022
- 19,080
It only takes one word to describe it.
AWESOME
AWESOME
The "right way" is subjective. If I were to design such a system, I would base it off an ESP32, add a voltage regulator that supports at least 48V, and include all the interface hardware in the box, which would interfaces directly with the ESP32, not going over USB. The hardware cost for such a box would likely be under $20. You already have WIFI and Bluetooth, and you could even add ethernet with POE for not much more. It also is more tolerant to temperature extremes, more fault tolerant, uses less power, is more secure, and is smaller.You can run it on windows via a virtual machine setup. I have done it to test stuff. Its just not supported that way.
The pi's are not but $60 turn key. That means you get an orange pi 3 lts board, case to put it in and a power supply.
So complete computer to run it on for $60.
It has to run 24/7 to be useful. There isn't a windows machine that will run at the low power levels of a pi setup. So its cheap to buy, cheap to run and bulletproof for the most part. You can also buy a 12 volt dc power supply for it so it can run off the dc part of your setup if you have 12volts. This means its automatically battery backed up with a power failure. This is how mine is running.
Its just the right way to do it all things considered.
Its accessible across the network from a pc too and also accessible via pc or your phone from anywhere in the world if the internet is reachable by the pi which has built in wifi too so that is easy to get on the net.
And in the process grossly violate the GPL, which is why I will never buy it. I have very small server cluster at home and there is no need for another Rasberry Pi to litter my home when I can easily spin up a virtual machine.The guys from sa created the drivers for inverters and batteries and packaged a collection of open source software packages together to make a complete solution
??Use it, love it, and it doesn’t void my warranty lolz
I don't use it for anything but monitoring my system.I like the idea of home automation, but who wants to be changing settings all the time if ever....I like set it and forget it for anything major and hardwired manual switches for the redundant equipment. Isn't there equipment and software already setup and marketed for home automation? I can see the draw to Solar Assistant only if there is some financial incentive to use SA over others.
Simply put it’s a nice app and interface to any solar system.I like the idea of home automation, but who wants to be changing settings all the time if ever....I like set it and forget it for anything major and hardwired manual switches for the redundant equipment. Isn't there equipment and software already setup and marketed for home automation? I can see the draw to Solar Assistant only if there is some financial incentive to use SA over others.
With SA and HA, it’s set it and forget it for changing settings. Can even alert your phone when conditions change if you want. No manual intervention. SA itself is great for metrics. The data can be greatly enhanced, merged with other data, and displayed however you like with HA/Grafana.I like the idea of home automation, but who wants to be changing settings all the time if ever....I like set it and forget it for anything major and hardwired manual switches for the redundant equipment. Isn't there equipment and software already setup and marketed for home automation? I can see the draw to Solar Assistant only if there is some financial incentive to use SA over others.
100% the same here.I don't use it for anything but monitoring my system.
But I like the ability to change something, if needed. From anywhere in the world.
I use the power supply Solar Assistant sells. https://solar-assistant.io/shop/products/dc_usb_psu_type_cUse it, and love it. Combined with Home Assistant, it turns on my hot water heater when there's PV power in excess of the heating element wattage so I can consume it instead of getting less ? from net-metering.
If you're connecting it to an inverter via RS232/RS485/etc. I recommend getting an isolated converter for extra protection to make sure that both the inverter and Solar Assistant box aren't damaged by voltage surges on the other device; I have one of the ones these guys make:
https://www.commfront.com/collections/rs232-rs485-rs422-ttl-serial-opto-isolators (no affiliation)
