another task completed: The solar Diversion load circuit installed and operational
I got the idea of this from this youtube video
there are several such videos on youtube
When my batteries reach 29.3 volts (per the battery manufacturer for bulk and absorption voltage) my batteries are FULL and current generation drops off. By using my panel charge controller which has an AUX control line that can be programed to go active upon various triggers I can capture that lost power.
So I am using array 1's AUX control line to engage a 12volt relay that activates 2 DC/AC Solid State Optic Relays which enables the AC circuit to start heating the water in the electric water heater
Below is the 12v activated relay with the AUX control line using yellow F type connectors
The low voltage outdoor 12 gauge wire (from HomeDepot in 100 ft segments) runs the POS line through the relay on the nut tightened connectors
This 12 gauge is over doing it, but I have several of these as 12v extension cords I use with HAM radio. This wire sources its power from my 12v solar panel on the roof, again powering my HAM shack.
Here another shot of the 12v relay ($12 at Amazon
https://www.amazon.com/gp/product/B07T35K8S2/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1)
Here the 12g wire connects to the Solar Panel input side of the Morningstar controller. Connecting it this way, there is power ONLY when the sun shines, when I want it. This way during the nighttime grid battery charge, it won't enable the water heater load
Here is the "orange" 10-3w/grd wire I showed earlier, connecting to the service panel. It currently will be driven by a 15 amp breaker @ only 120v since that is all my inverter is. Thus, using the 4000watt heater element, it will only consume 1000watts of solar panel power.
here is a link for various parts plus the math on that
http://waterheatertimer.org/How-to-wire-water-heater-for-120-Volt.html
Later with the new inverter, I will move it to a 20 amp 240v breaker, and install 2 2000watt AC heater elements
here are the 2 SS-Relays. Orange wire incoming power, and the armored wire running to the electric header, the other end in visible in the left foreground
The 12v black outdoor wire comes in the bottom of the SSRs. I am going to put a plexiglass cover over this, so the lights on the SSRs will be visible when active.
SSR Source:
https://www.amazon.com/gp/product/B0749JYKY8/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Heat Sink:
https://www.amazon.com/gp/product/B07C8R7MS2/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Shot of the water heater (with the Milwaukee battery charger on top) and the SSRs in the upper right
Here is a shot of the cold water line line (foreground left) and the hot water return line (foreground right) I just installed as well. Currently only one heater is install, but I have 2 heaters(left over from the thermal solar water heater project) and plumbed things so I can put 2 water heaters in series. I have a temp gauge on the hot water out line prior to the actual tankless gas water heater IN line, so I can read the temperature gain of the PV heater. Water currently is 45 F, anything higher than that is PLUS
My house was built in 1930 and had a crawl space. I spent 8 years digging a basement, 16'x30' paying neighborhood young men, 50 cents per 5 gallon bucket of dirt and rock that they would haul up and out. I know somewhat dumb, but recovering from a divorce, cash flow was low to buy a real house with a basement. We had this one and we continue to improve what we have. Getting close to paying OFF the mortgage.
Anyway, the diversion load system is very appealing to me and I will report how it works and how warm the water gets. 1000 watts isn't much, but right now when the battery is full, I have no where to send the solar current. Later with larger arrays, a larger 240v inverter, 2000 watt heater should work well
dougbert
