dougbert
continuing improvement on Array 4 with This Old House saga
Temporary position for these 2 panels on the wall for the winter. They will go up on the western roof next spring. For now, needed them high enough so they wouldn't be covered by snow (if and when we get some - we are in extreme drought conditions at the moment).
This was taken at 4PM MST and you can see how the fence has shadowed them, effectively turning them off for the night.
But at 12:30 PM (highest generation period) these two panels, while in full sun, reached 580watts of output. 2 - 355w panels
Tied, for now, into the new array 4 combiner
Peak production for the entire system touched 4.7kw near 1PM
![winter position on south wall.JPG winter position on south wall.JPG](https://diysolarforum.com/data/attachments/29/29152-8c1eef124e4587be3c3e80fe6ebbedec.jpg)
Setup to add new pigtails to another module tomorrow morning - only have a couple of hours a day before going to work online
Notice the horizontal then vertical conduit that goes from the crawl space to the combiner box on the wall.
On the other size of that wall is a staircase going to the basement, and I had been worried the conduit wouldn't fit before the top most stair, but I had a good 4 inches of space to install it.
(It will be great to get that wall covered with new siding)
![adding pigtails to module and combiner box.JPG adding pigtails to module and combiner box.JPG](https://diysolarforum.com/data/attachments/29/29153-b0c943af603cdcf4f0b23df7cbff6bb6.jpg)
Here is the combiner/disconnect box. Placed high on the wall because a deck will be built adding height to the floor, to the box will be at normal height once that deck is built
More 2x4s coming to be added on top of this wall along with 1.5" insulation. Then the conduit will be covered with siding
To the right of the combiner box I will also place, temporarily, 2 panels facing west for array 4.
These 4 plus the 2 on the roof will bring the panel count total to 6, which is also the number of panels on array 2 and 3 as well.
When that is done, total power will be in the 5.7wk range @ 24 volts
Both arrays 2 and 3 face south, while this array 4 will have the 2 facing south and 4 facing west
Also news, I ordered my 5th Tesla Model S battery today which will bring me up to 25kwh of battery storage
and hopefully reduce those early morning "grid connection" events as the battery SoC declines.
Later, battery 6 will be acquired as well
![array 4 combiner box.JPG array 4 combiner box.JPG](https://diysolarforum.com/data/attachments/29/29154-876bea054bf3cdd18c0c68fe6c22c0fc.jpg)
