Iconoclaster
Any able to tell me anything about error code 08 and what the hell happened after two weeks to my sungold inverter 10kwh?
I don't think I've seen that one. Were you able to clear it?Any able to tell me anything about error code 08 and what the hell happened after two weeks to my sungold inverter 10kwh?
times, worst case I had to shut everything down
I think most likely some sort of short circuit. I had very little running on the system. There’s no way I drew too much power.
short circuit
I’ve done three shutdowns. I contacted the manufacturers to send a video. But this is a strange problem since it was working fine for two weeks.
What's the VOC of your arrays?Any able to tell me anything about error code 08 and what the hell happened after two weeks to my sungold inverter 10kwh?
Yep...that's that closed loop krap at work.Here is 04
It won’t let me change it, I save close out of menu open right back up and it’s back to 49.2
My 61 use to say 10% but now says 14%
@Kenny_ and @CaliSunHarvester are you sure yours is letting you change ID 61?
If you change it to 18% save then close out, then open back up it will read %18?
"I’ve done three shutdowns. I contacted the manufacturers to send a video. But this is a strange problem since it was working fine for two weeks.
Restored to factory settings: only power on the machine via battery, Press and hold the UP and DOWN buttons simultaneously for 10 seconds , A flashing box will appear at the screen ,and will have tick tock, then shut off the machine,and reboot the machine." |
No. When I'm in User mode none of those SOC parms even show up.@Kenny_ and @CaliSunHarvester are you sure yours is letting you change ID 61?
Thank you! I couldn’t find this info anywhere."
Restart the inverter after restoring the factory settings (disconnect the mains, PV and batteries, reconnect the batteries after 5 minutes and switch the inverter on)
There is no Hard Reset other than to completely disconnect everything and wait maybe 5-10 minutes and then restart per the manual.I just disconnected everything possible. Yes, I do think it has something to so with the array, but not sure why. I have 130v - 160v in each PV connection and only maybe 3amps per. Seems unlikely it was over-voltage but there does not seem to be any other explanation. How long does I leave everything disconnected to ensure the reset? And is there no “hard” reset?
You're welcome. It came directly from SRNE when I had a random fault 12.Thank you! I couldn’t find this info anywhere.
What are your panel specs? 3A seems awfully low.I just disconnected everything possible. Yes, I do think it has something to so with the array, but not sure why. I have 130v - 160v in each PV connection and only maybe 3amps per. Seems unlikely it was over-voltage but there does not seem to be any other explanation. How long does I leave everything disconnected to ensure the reset? And is there no “hard” reset?
Good point that I should have made.You can also try the above to reset to factory but then you'll have to re-enter any changes/customizations you have made.
How do you have them wired? Series / parallel?You’re right it is low. At the moment it’s cloudy here so I can’t see what the Panels take in typically. But they are 14 200w 24v panels at the moment.
What is your array set up?I just disconnected everything possible. Yes, I do think it has something to so with the array, but not sure why. I have 130v - 160v in each PV connection and only maybe 3amps per. Seems unlikely it was over-voltage but there does not seem to be any other explanation. How long does I leave everything disconnected to ensure the reset? And is there no “hard” reset?
I have them set up four in series, then into a tie, those in parallel.
How does 4s go into 14? I'm confused.I have them set up four in series, then into a tie, those in parallel.
