Kenny_
Solar Wizard
EDIT:
the Wifi reporting works again. "They" upgraded their servers over the weekend.
EDIT:
You can actually run it without a battery. I think @Lighthouse Beacon was doing that before he got his first battery.I have a theory that the BMS on the battery is fried and that’s why it’s now giving me an over voltage alert and an under voltage alert today. I just don’t know how to test this hypothesis. I pulled the battery and ran the system. It seemed to work but I think the system needs a battery to run? Thx
Yeah man that’s great news. Run it with no battery. I did mine. It will just blink battery disconnected fault but will work correctly. Put it in SOL mode and try to carry a small load on solarI have a theory that the BMS on the battery is fried and that’s why it’s now giving me an over voltage alert and an under voltage alert today. I just don’t know how to test this hypothesis. I pulled the battery and ran the system. It seemed to work but I think the system needs a battery to run? Thx
That's with the battery completely disconnected, right?Now I get fault code 03 and 04 and 18.
Over Current? It’s got to be the inverter, right?
03 and 04 make sense with no battery.Now I get fault code 03 and 04 and 18.
No battery connectedThat's with the battery completely disconnected, right?
No Power Cables, No Communication, No Nothing.
wait.... 18? What's 18? Not listed in my manual.Now I get fault code 03 and 04 and 18.
I’m not sure what this means. Sounds a bit over my head.The easiest way would be to disconnect the battery and test for voltage at the terminals, if you have it disconnect all communications and switch to user settings to see if it works, if you don't have voltage connect without communications and force a charge to see if the BMS wakes up.
Bus Soft Start failurewait.... 18? What's 18? Not listed in my manual.
I'd say if the AC input breaker (on the inverter) is tripping, you've got a broke inverter.I’m pretty sure it’s the inverter. When there is no battery but, solar and AC power are on, the AC input breaker trips.
Completely remove battery, use a multimeter and check for voltage.I’m not sure what this means. Sounds a bit over my head.
Unit is acknowledging a failure in a sub-system. Errors 14-20 are inverter system side failures it seems, his original errors were noticing problems on the inverter output side. Bus bar inverter output side inconsistencies, errors 1-8. Yes he sounds like he’s released the magic smoke and the unit is now acknowledging the root of the problem, should just be the power inversion board. They had Holmes change his power board first, I wonder what SG will prescribe. Has Sungold emailed back?Completely remove battery, use a multimeter and check for voltage.
Based on fault 18 plus the breaker tripping your unit let the magic smoke out, like @Lighthouse Beacon suggested yesterday.
@CableGuy has a thread https://diysolarforum.com/threads/srne-hyp-series-vs-eg4-3000ehv-hf-series.76792/@42OhmsPA im ready to get my hands on a HYP. Is there anyone posting about them in the forum?
On my ECO5000 I tried the UP/DOWN thing with only battery connected a few times but nothing happened. Then I shut it down for 30 minutes. Then battery, then inverter. After it came up I held down the UP/DOWN. Then checked the parameters and indeed they got reset! Everything is now connected and with the PV1ST setting the PV provides all the load power."
Restart the inverter after restoring the factory settings (disconnect the mains, PV and batteries, reconnect the batteries after 5 minutes and switch the inverter on)
Restored to factory settings:
only power on the machine via battery, Press and hold the UP and DOWN buttons simultaneously for 10 seconds , A flashing box will appear at the screen ,and will have tick tock, then shut off the machine,and reboot the machine."
Glad it was helpful and great first post leaving more information to help others.On my ECO5000 I tried the UP/DOWN thing with only battery connected a few times but nothing happened. Then I shut it down for 30 minutes. Then battery, then inverter. After it came up I held down the UP/DOWN. Then checked the parameters and indeed they got reset! Everything is now connected and with the PV1ST setting the PV provides all the load power.
Are you going to:So I am headed to the SunGold lab in Orange County California with my inverter. They wanted me to ship it but it would cost much more to ship.
The inverter is most definitely fried. After following their instructions to check the inverter smoked. It’s a bit of a waste of time for everyone but I guess that’s what I have to do.
This should be interesting....So I am headed to the SunGold lab in Orange County California with my inverter. They wanted me to ship it but it would cost much more to ship.
