Kolek brought it up! I had to look it up myself. but it sounded like something a dodge owner would do.... I mean Cummin's ???My vocabulary has been expanded.
I hate for him to be blamed for my doingKolek brought it up! I had to look it up myself. but it sounded like something a dodge owner would do.... I mean Cummin's ???
your right.. my bust!I hate for him to be blamed for my doing![]()
@Hedges what you know about hot water elements? you are usually pretty knowledgeable.My vocabulary has been expanded.
Worse clones and overheating if under maximum load.
Mine tooMy vocabulary has been expanded.
Mine too![]()
It already knewOnly from your PC (so your wife doesn't see it.)
Google now knows your predilections.
Holy crap !
I wish I never looked that up.
Can someone tell me how to delete my search history?
Holy crap !
Couldn't you install the M8 items on something that makes them the same height? Like a backer of some sort. Thanks for posting pictures. I'm looking at doing this same thing for my setup. Where did you order your Class-T power in?I initially bought both the Lynx Class-T Power in and M10 Lynx Distributor thinking that I could’ve come up with a clean looking connection using a 1000A Smart Shunt in between but after all the research, a bit too tall at 2.7”to line up with the Power In and Distributor at about 1.25”. Although, I could’ve made it work and install a switch on the positive side above like in my RV but decided against the whole idea as it would’ve taken more space. Instead, I sent back the M10 Distributor and got a regular M8 Distributor with a Lynx Shunt and figured that it would be easier to modify it and only dealing with two connections versus four. The actual M10 cover are a bit bulkier than the M8 covers on the Lynx shunt and Distributor.
So the class T Lynx has a fair amount of vents, I wonder how much heat they are expecting for just 2 fuses vs 4 the mega fuses of the power in.
So the bus bars line up no issues but it’s the class T cover that just protrudes more that is rubbing you the wrong way?I’m a bit OCD and it really doesn’t look too bad so I’m just going to let it be. Right now the bussbars line up perfectly so putting something on the back will offset that and I want full contact on both bussbars.
Thanks to your link - I got it from the UK. I ordered on Friday and it got here yesterday. Shipping part sucked though but I’m trying to get the smaller stuff out of the way on my build and keep things moving along. I looked to the UK before when I thought of purchasing two newer Victron Orion XS’ to replace my two older 50A Victron Buck Boosts for the van but decided against it. Of course Europe gets the Victron goodies first.
Oh, so the busbars lined up correctly but the casing was mismatched? If so I think that's the route I'll do for my 4 Trophy batteries with two of the Class-T power in.I’m a bit OCD and it really doesn’t look too bad so I’m just going to let it be. Right now the bussbars line up perfectly so putting something on the back will offset that and I want full contact on both bussbars.
That’d be a tough one for me to pass on.
Yes, you're good with the bussbars lining up.Oh, so the busbars lined up correctly but the casing was mismatched? If so I think that's the route I'll do for my 4 Trophy batteries with two of the Class-T power in.
