Ok so I'm trying to understand how is using Wh being shady? According to upnorthandpersaul Wh is wrong and Ah should be used also 9/10 videos of capacity test I have seen are all using Ah.
Couple of reasons:
- For one, measuring Wh means tracking two variables (voltage and current) versus only one (current) over time. Energy is the area under the curve of these measurements over time. However, if you have losses anywhere in your set-up (like connections, wires, etc.) you won't measure those at your instrument due to these losses. AmpHours eliminate these losses altogether, and is the reason why this is chosen for battery testing - have a look at this extreme set-up I did:
- Secondly: a cell that is specified at 280Ah (in addition to whatever other means) means that it should deliver a constant 280A for one Hour. Or, at 0.2C, 56A for 5 hours. This is a very straight forward test, again, because losses don't matter (the current is the same everywhere in the circuit - see video again). If you measure anything less than that, it means it doesn't match the manufacturer specification and everything after that is handwaving.
- Handwaving: suppose you only measure 277Ah, but someone tells you that you measured this wrong, you should have measured Wh (which you reliably can't do with available consumer equipment) so they tell you that you should multiply this 277Ah with the nominal voltage of 3.25V. This gives you 900Wh, which is on the label as well, so all good! Or something along those lines. But, I hear you say, nominal voltage is 3.2V, not 3.25V? Their quote:
"Grade A cells provide the same watt-hours for less capacity e.g. 900WH at only 276AH vs Grade B cells that provide 900WH at 280 AH capacity.The watt-hour remains the same for both but grade A cells have average voltage of 3.25 vs 3.20 volts for grade B." - note that this was after they said that "We have tested our cells they all test above 281 AH we tested 3 cells and the highest tested to 285 AH." You can find these comments under [1].
By the way, have a look at their current site and the label on the batteries:
SunFunKits.com - Certified Automotive Grade A Genuine EVE Lithium LF280K Lithium Iron Phosphate Battery 280AH 4 pack - Sun fun kits
www.sunfunkits.com
No more mention of WattHours, all in AmpHours.
I called them today and they were upset with me on the phone saying I'm causing problems for them from Diy Solar Forum. Not my intentions but it is what it is I want to find out.
If any of my customers (or students) question what I said or am not clear about, and post these things in a forum where there are different views and they get it wrong - I would go into discussion with them, backing it up with science and data. Getting upset because of a discussion in my opinion means you've been wrong, don't want to admit it, and bury what was once said. If I then get proven wrong for whatever reason, I adjust to that accordingly. I wouldn't get upset about any of those things. Either I'm right, or I'm wrong. If I'm right, I back that up with data and science (like I have been doing on this matter for a long time). If I'm wrong, proven with evidence, I will happily take it but never would I get upset about it.
[1]
www.youtube.com/watch?v=rsO4ctUlCGY&lc=Ugywf-koQpjFph1p0Yp4AaABAg.9eIOjB47rBQ9eMZFiCxrMP
