Gotta say.. WOW some folks are seriously heavy on power use.
I could tell you that prior to my building my place, living in a "regular" structure, I used a lot more but that was due to structural & design deficiencies. I designed & built my home to be as energy efficient as I could... For all intents & purposes, it is a SIP (Structural Insulated Panel) type of construction. R32 walls which are also Thermally broken & with Rainscreen siding installation, R45 Cathedral Roof, also thermally broken and using a Cool Roof system. Even the foundation is a FPSF (Frost Protected Slab Foundation) with 4" of HD-XPS for R20 (code requires R10) which has Radiant Heating.
I'm averaging 3.5kwh per day, year round !
Before moving onto my property, I was easily using double that, after having trimmed off excess "junk" and switched to high efficiency appliances and devices.
But is IS a cheat - well not really...
The house cools itself in summer because of the roof & wall systems, the building does not absorb exterior heat. The slab once cooled acts as a thermo-regulator and as such, the house never gets warmer than 26°C/°78F, even when it is 38°C / 100°F outside. Again, also due to the Thermally broken walls & roof with the screening system, that prevents the cold outside from sucking the heat out of the structure.
Hot Water (On-Demand System), Radiant Heating (On-Demand System with glycol), cook stove are LPG (Propane) and the most I have used in one full year (12 months) was two 310 litre tanks for a total of 620 litres of propane. LPG was selected in advance for using BIO-GAS. Jetting etc don't have to be changed for it and the pressure regulators are identical. BTW, People in Alaska, North West Territories use BioGas successfully as well as the rest of the world... some places are just regressively slow to adopt the tech.
