xristostsilis
- Mar 24, 2022
- 109
When I bought them, they told me they are Grade A cells. What should I do?
i agree , these seem to be fake QR codes...This could very well be a fake QR code. The decoder at https://www.gobelpower.com/lifepo4_decoder.html also says the code length is wrong.
It could be that Docan has decided to remove the 'B' mark from the cell coming form EVE and replace the entire QR code - which I told them at some point not to do because it will cost them customers. Is this a sticker over the original one? Or erased and redone? Are the other QR codes the same number or is there a variation?
Alternatively, it could be that EVE changed code style and this is not recognized by the scanner yet, but I somehow doubt that..
test them, use themWhen I bought them, they told me they are Grade A cells. What should I do?
Thanks for sharing your experienceI didn't have much luck with APP scanner either on my EVE cells, looked mine up manually.
Here’s another QR. No, there’s not much variation between the 2 random picked cells. I don’t know whether it is a sticker or not. I”ll have to pull the whole black tape and I don’t wanna do that as I may have to speak with docan about it.
i will check them today, even if i don't peel the black cover, i can tell it's been sanded from the color differencePeel of the black covering see if you see sanding marks around the area where the QR code is, if you do then the took grade B cells with the B mark and re-lasered them.
See this guy: https://diysolarforum.com/threads/n...ese-eve-lf304-cells-new-ok.60171/#post-742713
hard to judge by the pictures and glue, but IMHO they dont look relaseredJust peeled off the black tape, how do they look?
Check the latest picturehard to judge by the pictures and glue, but IMHO they dont look relasered
