bc thunder
- Nov 28, 2021
- 16
New member, hope this is the proper thread....
Aug/21 I bought the 24v mpp AIO and four 6v 230ah gc batteries, and one 440w bifaical panel.
Good sun for 4hrs
I was underwelmed. I was told that's normal fro newbies, gobuy more.
I bought four more batteries of the same make, and one more 440 panel.
Still underwelmed, getting only 7 or 8 hours, using 100/150watts (that's all I have or need).
Then the AIO display started showing my brand new fridge using 165 watts instead of its normal 100watts, a few days later the fridge quit.
And I became aware the batteries were fast to recharge (20mins bulk). fast to charge/fast to depleat. FWIW I being new probably was not chrging them enough, as I was going by the display reading for SOC.
I finally bought the equiptment I should already have had, volt meter, and load tester were normal, but hydrometer read about 80% as my full SOC
The AIO started to not show watts being used (out going usage) and began turning off/on quickly 4/5 times in a row, once per day, daily or everyother day.
I replaced the 8 batteries with 4new of the same make, I tested them before putting into use. They were as low as 30%. I charged them as best I could with an old 40a charger and my honda 2200i. 90% was the best I could do, and tried them out. These alsogave me only 4 hrs approx @ 100/150watts.
I then bought a summet ll 24volt gc battery charger and using the balance mode, received the wifi data as having only 36ah of a possible 230.
Tired of it all, I also charged one old string of four 6v gc. they read 26ahs. I then hooked up both strings 0f four in series and parrl.
As the summet had stated I ran for about 6hrs to 60%. I then charged with the honda as usual. The next day I did the same, but when I stated the honda, after 90secs it began reving crazy high. I ran back to the shed and it was smoking. I shut it off and it would not start. Two hrs later it fired up, but I will not risk that again.
I will happily replace/fix any problem, but just don"t know what that is. Batteries??? AIO??? both??? Something else???
I have been getting help on small cabin forum, but we have not cracked the case!
A DIY member here reached out to me and suggested I try here.
PLEASE, if anyone here see's the problem, I"m out of answers, and out of my mind.......
Soory for my lack of tech knowledge, if you need more info, I'm happy to stumble along finding fro you.....
THANK YOU
Good sun for 4hrs
THANK YOU
