Batavian
What?? I had two inverters replaced because of F80s, the bonding screw was never mentioned with tech support.This bonding screw actually grounds the MPPT board in one area. It looks to get rid of noise at the same time. By adding this screw back to in the inverter we have seen F80s clear. The voltage stay stable when high PV voltage is being used, other nuisance problems that randomly accrued
One of my replacement inverters will throw F80 if I use PV1, I switched that string to the other inverter and it has been working so far. So I now have one inverter with only one MPPT functioning. I also have issues with PV sticking at 90v on my inverters. I have 79.71 installed manufacture date 10/22 and 42 enabled. I don't even know if I have a bonding screw installed. I also can't use the EG4 setting for batteries (6 Lifepower4) or the units will randomly shut down multiple time of day and night. I did check continuity between neutral and ground on inverter before installing, it was open. Could a bonding screw fix some of these issues?
