Kenny_
Solar Wizard
Nope that didn't work... I tried the modified cable both ways between battery and inverter.... nothing... just alarm ....
But the thing I didn't say before I started this change was that I plugged the comm cable supplied with the inverter back in and NO ALARM. There is something very screwy going on.
The cable supplied with the inverter appear to have inverted pins/colors i.e. pin 1 goes to pin 8,
The cable I modified appears to be a straight through cable I cut all but 7,8 and it seemed to work fine but no indication of multiple batteries/packs
also @Hedges I did try plugging in the modified cable (only 2 wires and ground) in both ways i.e. swapping ends between the battery and inverter...no difference, still an alarm 58.
and sorry about my inability to measure the voltages, etc. these pins are so tiny, etc..it's pretty much impossible for me to even try to do. I was having trouble just checking continuity trying to determine straight-through or reversed finally gave up... I can see the colors are reversed in the "inverter supplied comm cable"
The thing that gets me is that the inverter supplied cable was working for a week before error 58 showed up and I built the modified cable to fix it (i.e. just pins 7 and 8 straight-through to both ends). At that point I plugged the original inverter supplied cable in and got the error 58...plug the modified cable, no error. I tested this several times and then left the modified cable in until this afternoon when I tried the original supplied cable and NO ERROR. WTF?
