That's beautiful.View attachment 58366
Got all but one box. Is there anything I can do till the last one arrives?
I planned on hooking all 32 in parallel and top balancing them then breaking them into 2 48v batteries but didn’t know if I should start that without the last 2 cells and they all tested 3.289Assuming you will be doing a top charge in parallel to balance... you may as well get the stack connected on parallel.
If you plan to do in smaller batches (4 to 8?) you may as well get started. You may want to add some basic compression for the initial charge.
Good time to check voltage as delivered and index the cells to track during testing.
Depends on your power supply. If it is just 10 amps you may as well start. Otherwise just get them connected and make sure you have a solid connection from the supply to the bus.I planned on hooking all 32 in parallel and top balancing them then breaking them into 2 48v batteries but didn’t know if I should start that without the last 2 cells and they all tested 3.289
Cool I’ve got a good meter I’ll check it thanksYou beat me to it lol. I have th newer version of that PS that I bought for a small project and the least significant digit on both Voltage and current are way off. You must use a good volt meter to set the voltage.
