Hedges
I See Electromagnetic Fields!
- Mar 28, 2020
- 20,789
So each one has to have excess capacity for its loads.
Pacific North West can be a good source of hydro, to feed other regions.
Southern locations can be a good source of PV to feed regions socked in with clouds.
Infrastructure hasn't kept up with growth of population, and housing is being built where A/C is required.
Things are operating closer to the edge.
Controlling loads to shave peaks and fill valleys would reduce cost of power and make system more robust. Time of use rates and dynamic pricing could help get people/companies to shift.
I envision pagers integrated with thermostats to set them back 10 degrees. That could be offered with a 5% rate reduction for those who choose to adopt. Thermostat disconnect would be an even simpler to install device, but doesn't regulate demand as well. Some automated compliance testing would be needed. Adjusting thermostat briefly and checking meter is simple, but doesn't work if customer has A/C off.
Not likely we can get regions to do the regional power (increased cost for customers), but we as individuals can spend much more to supply our own critical loads.
I do think a stage of grid selective load shedding should be implemented prior to blackouts. Rolling blackouts is what they've come up with.
