I can't imagine that saves much if at all... There have been a few threads on it I think. I never really considered that approach other than when I need(ed) to charge from the grid I'd try to do it "Off Peak."Cancel the grid, disconnect completely and have @Kenny_ send you all the extra he generates.
Here is a question for which I have absolutely no answer (yet). For every 1kwh of power I pull from my battery bank, how many kwh of grid power does it take to replace/recharge the 1kwh. Can't be a one for one due to charger inefficiencies and can't be less as you would have something approaching perpetual motion. There are a number of folks on this forum who produce power during peak using solar and battery and charge the battery during off peak, are they really saving money?
That's a great question that my brain is to tired to put much thought into after work...Here is a question for which I have absolutely no answer (yet). For every 1kwh of power I pull from my battery bank, how many kwh of grid power does it take to replace/recharge the 1kwh. Can't be a one for one due to charger inefficiencies and can't be less as you would have something approaching perpetual motion. There are a number of folks on this forum who produce power during peak using solar and battery and charge the battery during off peak, are they really saving money?
True!!!Then he couldn't run that coffee maker
It is about TOU and the rates. Basically the load is shifted to off peak rates. If off peak was $0.30/Kwh and peak $0.54/Kwh, it sure would make a difference in the electric bill.Cancel the grid, disconnect completely and have @Kenny_ send you all the extra he generates.
Although it seems true; If it takes 2 kwh at $0.30/Kwh off peak to replace/charge each 1kwh pulled from the battery during peak hours I would be spending $0.60/Kwh to recharge the battery, not a savings but an increased cost. I would have been better off spending $0.54/Kwh during peak hours rather than pull it from the battery to recharge at what amounts to be a higher rate.It is about TOU and the rates. Basically the load is shifted to off peak rates. If off peak was $0.30/Kwh and peak $0.54/Kwh, it sure would make a difference in the electric bill.
One could make it pay if off peak is cheap enough and peak rate is high enough. Some places even have free electricity in the middle of the night so that would make sense to just have a battery bank and inverters, no PV.
how are they not mad about you about this? They must know something is upI do believe it's working...
The non logical side of me says cancel my grid service and use a generator for the really crappy times, I think it makes sense after the next expansions.
I could have done much better in the beginning of the year if I didn't use the grid to charge the batteries full on multiple occasions.
I don't know. I always pay my bill on time and leave a small credit, maybe that helps.how are they not mad about you about this? They must know something is up
Thanks.oh and congratulations
Charging efficiency will not be 50%. Take the EG4 Chargeverter as an example, the efficiency is 94% on 240V and 92% on 120V.Although it seems true; If it takes 2 kwh at $0.30/Kwh off peak to replace/charge each 1kwh pulled from the battery during peak hours I would be spending $0.60/Kwh to recharge the battery, not a savings but an increased cost. I would have been better off spending $0.54/Kwh during peak hours rather than pull it from the battery to recharge at what amounts to be a higher rate.
Again true.Charging efficiency will not be 50%. Take the EG4 Chargeverter as an example, the efficiency is 94% on 240V and 92% on 120V.
92% https://diysolarforum.com/threads/real-world-efficiency-of-lifepo4.6464/post-67686 That is still a long, long way from 50% loss. If peak is $0.54/Kwh, any rate under $0.45/Kwh is a gain.Again true.
What about the charge/discharge efficiency for LifePo4 cells or the battery as a whole including BMS induced losses. It all adds up.
Real world efficiency of LiFePO4
So I'm gearing up to jump in to LiFePO4 and as I calculate and estimate and my spreadsheet gets bigger and bigger, I'm wondering, how real are the charge / discharge efficiencies I read about online? I'm looking to put together a 48v system; where my battery bank will stay between 25% and 80%...diysolarforum.com
i am fairly close to you geographically. send me a message if you need help with anything. Otherwise, people here are both very smart and helpful. And congratulations, this thing is greatHello fellow SRNE ASF48100U200-H 10kw inverter user. i just got my inverter today (still in box) i would like help in setting up the inverter. If any of the users can share their settings that i can replicate so i don't have to experiment that much to get it working.
Currently i have MPP LV5048, i will be replacing that with this new SRNE.
Good morning East coast neighbor.Hello fellow SRNE ASF48100U200-H 10kw inverter user. i just got my inverter today (still in box) i would like help in setting up the inverter. If any of the users can share their settings that i can replicate so i don't have to experiment that much to get it working.
LV5048Good morning East coast neighbor.
First some questions that will help determine settings.
Battery chemistry?
Are you using communications with batteries?
How many batteries / capacity?
Specs of panels you will be using?
If you've setup an LV5048 in the past this will be easy for you. There are some additional options but nothing crazy.
