My other concern is that I'm going to blow in almost as much dust as air.
I think if I can somewhat seal the box, I'll be much better off come winter (hold in some heat)
Hum. My generator seems to be running fine. I mean you can hear when the load picks up (say the water pump kicks on,) but it seems to chug right along. My problems seem to be with the XW Pro. I can watch the status from the Conext Gateway and it seems to operate within tolerances I've set for the frequency ranges. It's just not using the "Generator Support Plus" feature. Also, the power cutting out when the generator goes offline is the big thing I'd like to fix. I'm going to change out the dead lead acid batteries in my UPS' with some used LiFePO4 so I can at least keep the computers going when the XW Pro trips the power.I had similar issue with my old Coleman MaxRun5000 generator. But in my case, it seems to mostly be the governor is just not working well. The RPM is changing far too much with load causing a frequency error and it cuts off back to battery and glitched out my PC and router as well. That made it a bit harder to see what was going on as I could not monitor it as it happened. I did spread out the frequency and voltage limits for AC2 input, but I have not tested it since. I want to try and reconfigure the governor linkage to make it more stable. I had installed a new carburetor a while back, and the holes in the arm are different, so the angle and radius are wrong for the stock linkage. With no load I was able to dial it in to 60 Hz and with a moderate load, it did not seem to hunt too bad, but when the XW-Pro tried to start charging from it at 2,000 watts, it went stupid. It sounded like it was just slamming full throttle to idle and back. And the XW just disconnected. To get some charge in the battery bank, I connected a stand alone 600 watt charger to the generator and that worked just fine. I was also able to move over the refrigerator to the generator output so the 600 watt charger could keep up with the inverter.
On a side note, I have my setup being monitored using Home Assistant. I was able to decipher Schneider's ModBus protocol and have a small application I wrote running on my server that provides an API interface for Home Assistant to query and show me information on Battery SOC, Battery Volts, Battery Temp, Inverter load and state, PV arrays output (I have 2) and charge status along with some temperature reading from the equipment room as well as the Heater and A/C status/control I have keeping that room warm and cool for the batteries and equipment. I just ordered a new "CAN Bus RS485 Protocol Battery Active Equalizer Balance Bluetooth 2S ~ 24S BMS" so I'll use the RS485 interface to get cell status into Home Assistant as well. Then I'll have a complete, automated battery/solar/inverter monitoring solution that I can access from anywhere I have internet.
The Modbus command to force Bulk Charge isHave you found a command to bulk charge with the XW? I was just looking a few minutes ago and didn't see anything. But, I haven't given up yet.
