Knowing ss, if you ever connect sa , even wirelessly, the warranty is voidedNah if its in the house or building at all SS knows SA will sneak into the room in the middle of the night and slaughter all eg4 equipment
Yes my Pie with SA is in my basement next to the router. The Inverters are in my detached garage.Thanks!. Wirelessly?
Wireless?
How?
EG4 model | Inverter port | Cable |
EX range | RS232 | RS232 USB cable |
Micro USB | Micro USB cable | |
EHV range | RS232 | RS232 USB cable WiFi dongle DB9 cable + USB serial cable |
USB type B | Not usable for monitoring | |
18KPV Luxpower | No physical connection | Connects via local network |
You would need to have @Markus_EG4 or another representative answer that question.Dang that's impressive. I assume if there is no hardware connection that sa cannot void the 6000xp warranty?
Voodoo magic.Wireless?
How?
They sent you the wrong unit to test.
@n2aws interested in what you want tested.
???Can I use Solar Assistant?
Solar Assistant is not a supported accessory for the 6000XP, and we do not recommend using it.
Priceless ?
That's the experimental ninja model that is designed to hide from Solar AssistantThey sent you the wrong unit to test.
I've never heard of a qxoood. lol
Haha, I cropped myself out of the selfie.They sent you the wrong unit to test.
SA DOES NOT VOID WARRANTY. Luxpower is looking at testing SA to add to the list. It just hasn't happened yetYou would need to have @Markus_EG4 or another representative answer that question.
I would sure hope not.
Voodoo magic.
"Monitoring connection
No cable is required to monitor the luxpower inverter. SolarAssistant connects via the local WiFi network to the Luxpower WiFi dongle. Monitoring is real time and doesn't go through the internet."
Does it have the same TOU features as the 18k?3 things I will leak: idle wattage under 50, retail $1399, uses the same monitoring platform as the 18kpv
Might want to let SS know about that. Just to be on the safe sideSA DOES NOT VOID WARRANTY. Luxpower is looking at test SA to add to the list. It just hasnt happened yet
In the manual it seems to have 3 grid load time slots and 3 grid charge time slots.Does it have the same TOU features as the 18k?
thats what happens when you use selfie mode. I never use it so didn't realize it was flipped. Somebody in a PM wanted proof that I actually had the 6000xpI was referring to it being a mirror image. lol
Thanks, I thumbed quickly through the manual. Then watched Wills vid, then found this thread.In the manual it seems to have 3 grid load time slots and 3 grid charge time slots.
Duplicate…DeleteDoes it have the same TOU features as the 18k?
At least this new inverter is pretty inexpensive. So if the warranty gets voided, oh well.Knowing ss, if you ever connect sa , even wirelessly, the warranty is voided
Isn’t the warranty only 2 years versus 5 years on the 18kpv model?At least this new inverter is pretty inexpensive. So if the warranty gets voided, oh well.
Its probably 2 years vs 5 years but all of their stuff gets lifetime support on the forums here it seemsIsn’t the warranty only 2 years versus 5 years on the 18kpv model?
