Sure, never said it was a sane solution. The European code as a whole is a heck of a lot more sane than the one in the States...
Between the US electric code and the AHJs for that and everything else, we've effectively killed the pioneering, adventurous, inventive spirit here in the US. I think in some places you're not even supposed to change a receptacle without a permit.
Let's make sure we pad every corner so no one gets hurt. McDs coffee cup with the label "contents may be hot"...need I say more.
Starbucks: "The cup of coffee you're about to enjoy contains chemicals known to the State of California to cause cancer."
You could be correct but my impression is that the suppliers are seeing a broad-based reduction in cell purchases..... not just through @Will Prowse links.I would argue that just because Will is seeing lower revenue doesn't mean people are buying fewer cells. It could mean that the DIY folks are using other sources or they have purchased from his sources without going through his affiliate links.
Yes, it's the actual distributors that tell me this.You could be correct but my impression is that the suppliers are seeing a broad-based reduction in cell purchases..... not just through @Will Prowse links.
It was a good run while it lasted!!! ?It is crazy how many people were buying cells through my links last year, versus late 2021-now. Massive difference.
I think you stated grade A cells were at $0.24/Wh currently, while grade B cells from China could be had for $0.17/Wh and OTS rackmoumt batteries such as EG4 could be had for $0.29.Yes, it's the actual distributors that tell me this.
It is quite possible that amy with docan power is taking over the market, volume wise. I have setup my affiliate account with them but have never sold any through their site.
Or it could be that more people are buying from Alibaba distributors.
Distributors have told me that I am usually #1 or #2 biggest affiliate, so when I see a massive drop, it usually means people are less interested. Case in point is ecpc. Great batteries but there are other batteries that are slightly cheaper, so their performance has gone down on my end.
But yes I use link performance and what the distributors tell me over the phone to draw these conclusions.
So that’s only a ~21% premium to avoid the trouble, risk, and anxiety of DIY if getting the good stuff and only a ~71% premium if you want to add in the risk and delay of getting aftermarket cells of unknown origin and quality from China.
Amy quoted me $0.18 per watt 280Ah with shipping on last quote a month ago. The first order with her 6 months prior was cheaper. Much of the increase is shipping cost. 35 to 45 days shipping.I think you stated grade A cells were at $0.24/Wh currently, while grade B cells from China could be had for $0.17/Wh and OTS rackmoumt batteries such as EG4 could be had for $0.29.
I got my (probably) grade 16 B 280Ah EVE cells through AliExpress a year ago (when there were no other options) for $1400 delivered, so under $0.10/Wh. But I had to screw around capacity testing and then getting the vendor to replace a defective cell and who knows what lifetime I’ll end up getting from this budget DIY battery.
Those who love to screw around building batteries will continue to do so but for the vast majority of DIYers who have other projects they’d rather spend their time on, the peak DIY LiFePO4 battery era is behind us…
(I saw the writing on the wall late last year when I was looking for an OTS battery for a family member who had no interest in DIY and discovered the EG4 batteries for $0.29/kWh)
Personally I avoid affiliate links like the plague, and I'm sure I'm not alone.I would argue that just because Will is seeing lower revenue doesn't mean people are buying fewer cells. It could mean that the DIY folks are using other sources or they have purchased from his sources without going through his affiliate links.
