I have received 32 EVE 230 Ah cells from Docan's Houston TX stock and 31 look pristine. They all measure 3.293 volts out of the box.
Number 32 is only reading 3.286 volts and also appears to have a defective weld on one side of the negative terminal. The square tab with the stud has a stepped down lip that gets welded, and it looks like this one was misaligned in the jig so the weld landed on the lip instead of the joint between the lip and top of the cell. I have emailed Docan and will be posting about the response.
I have mixed feelings about this new stud welding method. The surface area for the bus bar is large and flat. The square tab is only welded on 2 sides and if you hold it up to the light and squint just right, you can see the slimmest of a gap. I think this will be fine for most solar storage applications that typically have a lower C rate, and is probably more robust than I'm giving it credit for.
The cells themselves are mostly flat with a slight concave depression between the electrodes. It's only noticeable using a straightedge and will probably fill out with a full charge.
It's nice to see they are simply attaching a Docan label instead of the fake IR test sticker they used to apply. This seems more honest to me. The supplied bus bars are the thin layered ones and I actually prefer these to the thick stock.
I don't have the equipment to do a proper capacity test and for me, it really doesn't matter. I already have 2 batteries made from these cells and expect this batch to be the same. With a combined capacity of 230ah x 4, a few amp hours one way or the other isn't going to be much of a percentage of the total system capacity.
I would be 100% happy with this purchase if it weren't for the one defective weld, and how Docan deals with that will be a critical to my recommending these cells and Docan.
Stay tuned....
View attachment 153691View attachment 153692View attachment 153693View attachment 153694View attachment 153695View attachment 153696View attachment 153697View attachment 153698View attachment 153699
