Thanks
The Andersons I bought direct from Powerwerx. I have seen stories of the ones on Amazon being fakes or knockoffs.
I bought the 2nd SCC because the Growatt 12k Inverter AIO is rated for a 7000 watt array (3500 on PV1 and 3500 on PV2) And we have a total of 11,800 watts. You can over panel the Growatt a little (maybe) , but not that much. So to not waste the extra power and risk melting something down we got the 2nd SCC.
This will be the basic idea of our final wiring (most of it is completed now in the t railer). Solar will be out on the roof of the barn and I will build up another Anderson connector box to mount on the pole. I am using 10 awg from panels to combiner, and 8 awg from combiners to SCCs
On the sub panel (which is functioning as the main panel where Neutral and Ground are bonded), One 60 amp breaker is the main in from the Growatt, The other 60 amp is Main power out that will go to a larger distribution Sub Panel mounter perminantly at the farm. This will connect via teh 60 amp 6 awg generator cable. This panel will feed the whole farm.
The 15 amp and Two 20 amp breakers feed the light and recepticle next to the panel (15 amp) and each 20 amp feeds 1 recpticle in the double recpticle box. One on L1 and one on L2 to help keep loads balanced at the inverter.
Have no idea why you cant see the video. It is just a typical youtube video. Can you see other videos on youtube? I do not make my videos for kids so if you have somekind of youtube parental controls that might be why
