@MrM1 @SpongeboB Sinewave @Hedges @Horsefly @RCinFLA
Could y'all please make some recommendations on exactly what size/type resistor i need to pre-charge the inverter? I've seen lots of suggestions and I guess I was going to try the 50 ohm 100 watt unit with a push button switch since i need something permanent.
Honestly, I'm hesitant to even try this, based on what MrM1 has to say in his thread about wiring his pre-charge system but I feel like I don't have any other good options at this point.
I'm going to order what's needed tonight so i can try this later.
Thanks in advance
First of all, don't be too afraid. The current through the pre-charge resistor can be a fair amount, but it is for such a fraction of a second that it doesn't really matter. A 50 ohm 100 watt is fine. I use a 10 ohm 50 watt on my 24V system, and it works great. Don't be scared!
The problem: When the capacitors on the front-end of an inverter are completely depleted (after a couple of minutes of no power), the capacitors appear as a dead short to any DC source connected to the Inverter. So when you connect up a bank of LiFePO4 batteries, they are presented a dead-short, so there is the potential (with LFP batteries) for 1000's of amps. Thing is, that dead-short goes away really quickly. The capacitors charge back up and balance is achieved. Problem is, during that fraction of a second your BMS sees a ton of current, and after the BMS cuts off current the Inverter sees no voltage. No one is happy.
The math is pretty simple. If you have say 53V and a 50 ohm resistor, if the capacitors look like a dead short the current is only 53/50 = a bit over 1 amp, which is only 53W of power. Remembering that this rush of current is very brief, it probably makes more sense to go with something like 10 ohms, which means you have a bit over 5A of current, and maybe 250W of power. BUT, since the rush is so short, you don't need to size the resistor for 250W. 100W (or even lower) will do.
If you use a larger resistor, you - strictly speaking - need to allow the pre-charge to go for longer. In practice, I'm not sure this matters. Humans won't notice much difference between a 5/100's of a second and 3/4's of a second.
@FilterGuy wrote up a good resource on the pre-charge, and you might want to look at that. I think he was way too conservative on the current, ratings of the resistor, etc., but I guess it's better to be too conservative on such things than to just wing it.
