DerpsyDoodler
- Jan 10, 2021
- 2,247
Yes, Chargery; and the DCC contactors [edit: assuming I go with chargery’s DCCs] will be on the positive leads with iso boards.I'm not following this, what do you mean by fusing each B+ post-bms, the BMS (if inline) generally would be on the negative side. Are you using a BMS with external control (relays)?
edit: actually, fuses will go pre-DCC. I think that makes more sense.
