You have it ac coupled to a pv inverter? DetailsSungold. I'm running a tp6048 hybrid and love it.
To me ac coupling is being able to charge a battery via the output of a grid tied inverterI don't believe it's a true AC couple. My understanding of AC coupling is using a blend of solar, batteries and grid at the same time to cover loads.
Someone please educate me further if that isn't correct.
i assume its micro inverters feeding AIO inverter through the generator portI don't believe it's a true AC couple. My understanding of AC coupling is using a blend of solar, batteries and grid at the same time to cover loads.
That is more of what a hybrid inverter is. AC coupling is being able to use solar power from a separate grid tied inverter.I don't believe it's a true AC couple. My understanding of AC coupling is using a blend of solar, batteries and grid at the same time to cover loads.
Thanks.Sma Sunny island, outback, eg4 18kpv
Midnite
Apparently the new mpp solar 10kw
They list ac coupled for the ip6048 but it seems to work the same as the tp so I'm not positive.I don't believe it's a true AC couple. My understanding of AC coupling is using a blend of solar, batteries and grid at the same time to cover loads.
You can get sunny Island a lot cheaper . On eBay I see sunny islands for $2k all the time. Two of those is 12kw and would be in a class above s*lark.Thanks.
The S*lark 8K is $5K, so Sunny Island is same $ for less W, Outback GS8048 is more $ for ~same W, and E4 18kpv is just rebadged LuxPowerTek.
I’m specifically looking for AC-coupled options at price points below that of S*lark and no higher than those of the:
Conext SW ($1600 for 4400W)
Conext XW-Pro ($3500 for 6800W)
Magnum PAE ($2200 for 4400W)
I didn’t know that MPP had a new AC-coupled offering nor that Midnight has an AC-coupled offering, so thanks for that.
There is also a new range of AC-coupled offerings being introduced by Hoymiles, though it is too early to say where they will end up
being priced.
I guess we’ve got the (preliminary) Nov ‘23 list.
Ahh, if that's the case @Crowz is correct.To me ac coupling is being able to charge a battery via the output of a grid tied inverter
I really should try to test this with my SRNE down the road when I get most of my other open projects done.i assume its micro inverters feeding AIO inverter through the generator port
Thanks. So you would feed the AC output from a grid tied inverter to the input of another inverter to charge batteries?That is more of what a hybrid inverter is. AC coupling is being able to use solar power from a separate grid tied inverter.
You probably know as much as I do on who can AC couple. It's not a feature that I have any interest in.Well since there is no list anywhere, I’ll ask here.
Aside from Schneider, Victron, Magnum, and They-Who-Shall-Not-Be-Named (S*lark), who else offers hybrid inverters that can AC-couple to solar power connected to the AC-output? (At prices below the inflated offerings of S*lark)
Anything from Growatt?
Solis?
SRNE?
Others?
I think this is the main difference between the ip and the tp. "AC Coupled (single unit support): You can connect the AC output of the grid-tie inverter to this solar inverter's AC output, which will convert the grid-tied system into a Hybrid (grid-interactive with battery backup) system." If you tried this with the tp I bet the magic smoke would escape because it can't sync frequency.They list ac coupled for the ip6048 but it seems to work the same as the tp so I'm not positive.
The ability to receive power from and control a grid-tied inverter.I don't believe it's a true AC couple. My understanding of AC coupling is using a blend of solar, batteries and grid at the same time to cover loads.
The simplest way I think of AC-coupling is that you have no DC-coupling (no MPPT, integrated or external) and only have AC-coupled solar power available.That is more of what a hybrid inverter is. AC coupling is being able to use solar power from a separate grid tied inverter.
Deye all day, someday.Glad I'm not the only one who is #neversolark ?
Pretty certain that is just flushing inventory of the obsolete design. You’re never going to get UL 9540 with one of those and could run into issues getting AHJ approval. No eBay included (at least in my list).You can get sunny Island a lot cheaper . On eBay I see sunny islands for $2k all the time. Two of those is 12kw and would be in a class above s*lark.
Who knows whether thy have pushed Deye to introduce features they were not already planning on their own or not, but that’s about the only possible contribution they may have made to the State of the Art.Glad I'm not the only one who is #neversolark ?
Amen!Deye all day, someday.
It's gonna be hard without integration between the inverters to be able to get tightly controller zero export.There are a number of AC-coupled hybrids that support AC-coupling when off-grid but they almost all require an export agreement when on-grid (Hoymiles potentially being one of the first to support True Zero Export when in-grid, but too early to say whether that is only with in-family Hoymiles Microinverters or with any 3rd-party grid-tied solar inverter…).
That’s certainly the minimum, to be able to operate off-grid with AC-coupled solar power tied to the gen port rather than DC-coupled solar power tied to an SCC (integrated or discrete).The ability to receive power from and control a grid-tied inverter.
While pretending to be the grid.
Except we can’t purchase them here…Deye all day, someday.
And I’m guessing they offer far better customer support than an MPP Solar or a Growatt.
At least they have done a good enough job supporting installers to have achieved the penetration they have with that community.
I have nothing against the company except first and foremost the misleading marketing (‘made in the USA’ apparently now means moving off of a palette from China and placing into an individual unit box) and secondly that they are just too expensive for what they do.
I believe it’s that second factor of ‘Chinese technology at American Prices’ that has you predicting their demise.
For sure we’ll be seeing an increasing range of ‘Chinese Technology at Chinese Prices’ soon but whether that ends up cutting into Solark’s success with installers enough to drive them to more reasonable pricing remains to be seen…
Isn't ul9540 a battery standard?Pretty certain that is just flushing inventory of the obsolete design. You’re never going to get UL 9540 with one of those and could run into issues getting AHJ approval. No eBay included (at least in my list).
Not really. LuxPowerTek already offers a single-phase AC-coupled inverter with that capability: https://luxpowertek.com/lxp-acs-3600It's gonna be hard without integration between the inverters to be able to get tightly controller zero export.
Yes, forgot Enphase on my List (though they are even more expensive expensive than Solark once all the bits and pieces are added up…).Enphase's micro inverter and battery system I believe also supports zero export.
Agreed, I'd try it just to have something else to tinker with and exercise the brain but the more I read about the less interest I have ?.Unless you already had micro inverters I don't see why one would want that to start with.
I don't think Schneider or victron have it either.
I'm not sure how this is different from the ac-coupling available in hybrid inverters like the sol-ark or 18kpv.Not really. LuxPowerTek already offers a single-phase AC-coupled inverter with that capability: https://luxpowertek.com/lxp-acs-3600
(Download the manual and read about ‘Mode 1’ and ‘Mode 2’).
I believe it is a standard for hybrid + battery pairing (though a new version for each alone is apparently emerging).Isn't ul9540 a battery standard?
If I needed to purchase today, I’d pretty much agree (or the new 10kW SRNE). I’ve got a year+ so will watch the evolution of the landscape unfold…I would take that obsolete technology any day over a s*###k or 18kpv any day
Didn’t know that and good to hear.The 18kpv has already cut into solark success- so much so they dropped their prices.
I’m 110% with you. I don’t know that we’ll see 12kW for $3K, but the SRNE 10K is under $2000 and I’m pretty certain we’re going to see Solark-like hybrids in the 8-10K range for under $3000 within the next 12-18 months…Let another competent box come out in the $3k range and it's pretty much game over for solark. Solar companies are hurting right now due to the demise of net metering- they will be looking for more cost effective solutions
