for me stainless steel is at the bottom of conductivity list, so i would even prefer aluminium (best after gold and copper) or at worst Brass.
Iron would be ok, but Iron rust very fast, and the contact in the battery is made from aluminium, so there is less chance to get the screw stuck in the threading by some chemical reaction between two different metals.
from what i calculated (this is not indicated in the spec sheet) diameter of battery contact is about 16mm
so, i will made my copper bar (25mm wide) clean, drill the M4 hole, cover both side of the hole with a sticker about 18-20mm diam. and varnish the copper strip with transparent varnish. then remove sticker to expose copper.
this way i will get clean copper and able to see trough varnish if problem (oxidation) occurs anyway.
it is recommended to use big copper/aluminium plate to join the electrod (not only for current) , but because they can act as heatsink to
regultate the heat of the battery. it seems it is more efficient to catch heat from this place, than waiting it reach te outside of the case.
using aluminium heatsink with fins could even be a good idea to get
1) same metal on on contacts (all aluminium) for oxydation
2) good conductivity
3) cheaper than copper
4) good thermal dissipation
![1579607577163.png 1579607577163.png](https://diysolarforum.com/data/attachments/5/5556-29403f841ec4e2b01d93b3eb354fc19f.jpg)
