Zwy
Emperor Of Solar
My opinion after building a bank over 50Kwh, you capture more yield from panels with a larger bank. This extra yield can be put to use.My system is running well. I have 6 EG4-LL's for 31kwh of total storage. My daily consumption is 25-30kwh.
When there is back to back sunny days all is good. When it turns cloudy for a few days I have to run off the grid.
I can run only about 1 day without sun. I don't think my investment will ever pay for itself but I think the added security for grid down senerios is worth it.
I'm contemplating going further into the solar $$$ hole by buying another 6 EG4-LL batteries doubling my capacity to 62kwh.
I'm sure I can trim my energy usage some but I live in Ohio and feel like my system sits idle too much. Double battery capacity would give me a lot more use before I need to go to grid, not 100% but a lot more. Should I bite the bullet ? The batteries are on sale now with the 6 slot rack "free". If I'm going to do it , might as well get it on sale - vs. full price. Any thoughts on this ? Thanks
We normally use between 15Kwh to 20Kwh average on a daily basis. Yesterday, we used 54Kwh, I'm taking advantage of the extra PV once the batteries are full by running electric heaters (mini splits to be installed this summer). I look at it as free energy just waiting to be harvested. With the large bank, you can use this power thru the whole day, not just when the sun shines.
Part of the reason I moved to solar was to be able to move most home heating in spring and fall by using the excess. It is working out well.
